Old 10-15-2006, 12:25 PM
waterlogged waterlogged is offline
Rep: 10 Posts: 2
jet drive not thrusting
I have a 1995 Dynasty Sport Jet 120 that has been totally overhauled. After getting the engine to finally fire and run, once in the water the jet drive starting slipping. Finally, it quit thrusting all together but the engine would still fire right up. Checked the shaft and impeller and they both turn when the engine is running, but still no thrust out of the jet drive. Any suggestions on what I might do or what could be causing this problem. TIA.
Adam
Old 10-15-2006, 12:36 PM
stevel stevel is offline
Lost at sea
Rep: 15 Posts: 118
Is the intake blocked?
If the impeller is intact and turning, my first guess would be a blockage on the intake side.
Old 10-15-2006, 01:20 PM
Rep: 10 Posts: 2
Not sure what you mean by intake side. I have taken the intake grate on bottom of boat off and found nothing blocking it.
Old 10-15-2006, 01:21 PM
Lost at sea
Rep: 15 Posts: 118
That is what I meant
That was my guess.
Old 10-17-2006, 11:40 PM
StianM's Avatar
StianM StianM is offline
Rep: 114 Posts: 577
If you still have the problem I would sugest checking if anny coupling is sliping.
Maybe the impeler is rotating only when it's unloaded and once loaded some coupling will slip.
Jet, Jet Pump, Waterjet, Jet Drive vs Prop brian eiland Jet Drives 45 08-27-2010 08:04 PM
jet drive Joinery Designs Propulsion 1 04-11-2008 07:31 PM
jet drive pricey797 Jet Drives 2 05-30-2007 03:40 AM
Jet Drive Jet Drives 15 12-18-2006 09:51 AM
Jet Drive CMP Marketplace 20 02-28-2006 07:38 AM
