| Jet drive identification and rating Hi, I am removing a jet drive unit from a 12'6" jetboat. I don't know what engine it had before as it is a bare hull but suspect it was a car engine as there is a step up drive (1:1.5) to increase the revs from the engine to the pump shaft. Before I spend time cleaning the unit up, I'm trying to deduce if this jet unit would be suitable for coupling up to a 120hp motorcycle engine in a similar hull. The jet drive is a 2 stage unit with a glassfibre, moulded into the hull pickup tube and aluminium parts outside the hull. It has 150mm impellers (x2) and tube.The impellers are bronze. It has a makers plate on the reverse bucket which says: JET UNIT: MODEL NO 64 SERIAL NO 1117 UA ENG. LTD SHEFFIELD. Am I wasting my time with this old 2 stage jet? I note jet units now tend to be single stage. Second question: It needs cleaning up. How do I restore the old pitted oxidised aluminium to better condition, are there special paints and primers i should use? |
| pp jet identification | kcmd | Jet Drives | 5 | 08-01-2009 12:43 AM |
| Jet, Jet Pump, Waterjet, Jet Drive vs Prop | brian eiland | Jet Drives | 25 | 06-20-2008 05:23 PM |
| Converting from Jet drive to Stern drive | gearhead496 | Boat Design | 9 | 03-22-2008 12:23 PM |
| help old jet drive | ahoyjohnboy | Jet Drives | 0 | 11-01-2007 04:22 PM |
| jet drive? or stern drive? | Toby100000 | Jet Drives | 2 | 08-04-2007 04:32 AM |
