Old 03-02-2007, 08:38 AM
Rusty Bucket Rusty Bucket is offline
Rep: 26 Posts: 76
jet drive on flat bottom
I am currently building a 25' alum. dory skiff, it has about 22' of flat bottom 5' wide. The guys at hamilton jet told me that flat bottoms don't work well with conv. jet drives but my experience with jet boats was that most of them were pretty flat. Boat will be used for inshore comm. fishing. Any comment will be appreciated. Rusty
Old 03-02-2007, 11:51 AM
tri - star tri - star is offline
Rep: 3 Posts: 87
Flat Bottoms ?!
To Rusty Bucket,
If you hit the search button - put in " jets, jet pumps...."
you will see a lot on jets.
I draw your attention to the THIRD quote down on this post.
Re: the EFFICIENCY of jets. Which I agree with.
The dory is unquestionably, a seaworthy and practical vessel.
However, there are some KEY concerns where dory design and
good practice in jet design don't easily go together.
....'ole Mr. Hamilton would also advise you to have a fairly
CONSTANT geometry for at least 6 ft. ahead of the intake.
This isn't so in a dory.
After all - it gets it's forgiving nature - by the very fact that
the curves in the chines VARY the geometry......
It IS possible to make some kind of - high thrust, low speed
- industrial type jet work in your boat.
I'm up to the challange.....did it with a vessel like yours.
However, dispite my cleverness, the final results will
likely disapoint you.
Cheers !
Old 03-02-2007, 06:20 PM
Rep: 26 Posts: 76
flat bottom jet
Thanks everybody for the info. I have actually already configured the boat for an outboard and the information you directed me to just confirmed what I have been told by the Hamilton Jet dealer, I appreciate their honesty. This is a classy forum.
Old 03-02-2007, 06:40 PM
Tim B Tim B is offline
Rep: 279 Posts: 1,125
The problem with all flat-bottomed boats (not just waterjets) is directional stability and control. Notably, that on a flat-bottomed boat there isn't any. You'll need to put a fair-sized skeg on the boat to re-gain some of the directional stabilty that would have been present with a V hull.
Flat-bottomed boats tend to slam a lot and slide round corners a bit like a hovercraft. That's why so many boats have deadrise.
From a jet inflow point of view, you don't want any massive change in geometry (steps etc.) ahead of the inlet, but smooth, fair variations in geometry should not pose a problem. You certainly can't get much better than a flat bottom for inflow purposes.
Tim B.
Supported by engineering.selfip.org
Old 03-26-2007, 12:42 PM
KawRiverrat KawRiverrat is offline
Rep: 10 Posts: 3
Rusty, one of the biggest issues with a flat bottom when running a jet is cavitation. A slight bit of dead rise is desired to split any air before it is in jested into the pump. This can also be achieved with a radius design . But much harder for a home builder to achieve. If running shallow water is desired a delta pad design is my favorite
Old 05-11-2007, 01:17 AM
breammaster breammaster is offline
Rusty,
I have just been through what you are looking to do, and ended up building a false bottom over the previous flat bottom on my flats skiff. Check out nzjetboating.com, and look in the projects section (inside the forums) for "jet powered flats fishing boat". Heaps of photo's of how I went about it, and the result.
Hope this helps.
Cheers
Warren.
Jet, Jet Pump, Waterjet, Jet Drive vs Prop brian eiland Jet Drives 25 06-20-2008 05:23 PM
Rhinomarine3d and a sailyacht with a flat bottom Arvy Software 11 08-31-2006 05:22 AM
Flat Bottom Jet Tunnel dick stave Boat Design 4 04-14-2006 02:56 PM
About Flat Bottom Boats.....? jfnewell1965 Powerboats 9 12-05-2005 11:03 AM
Flat Bottom Boat Marsh Man Open Discussion 9 05-18-2004 04:01 PM
