Old 08-14-2006, 05:17 AM
pricey797 pricey797 is offline
Rep: 10 Posts: 8
jet drive
hi i have just purchasedmy first boat with jet drive and i am very impressed,only thing is i would like to know how i can flush engine out without damaging the jet drive impellor,can somebody tell me how long i can run the unit without water if i can thank you
Old 08-15-2006, 05:44 PM
Riverjet502 Riverjet502 is offline
Rep: 15 Posts: 8
The only way to run a jet pump out of the water is to disconnect the pump shaft from the engine. Very hard on pumps to run dry.
Old 05-30-2007, 04:40 AM
tabtidwell tabtidwell is offline
Rep: 10 Posts: 3
whatever you do, do not run your jet out of the water for more than 30 sec. if so you WILL damage the wear ring inside of the pump housing. dissconnect the drive shaft from the motor and make sure that your exhaust is also disconnected from the water inlet if not then your engine will fill up with water.
Jet, Jet Pump, Waterjet, Jet Drive vs Prop brian eiland Jet Drives 45 08-27-2010 09:04 PM
jet drive Joinery Designs Propulsion 1 04-11-2008 08:31 PM
Jet Drive Jet Drives 15 12-18-2006 10:51 AM
Jet Drive CMP Marketplace 20 02-28-2006 08:38 AM
Jet drive? Danielsan Propulsion 8 02-09-2005 05:21 PM
