Old 07-03-2006, 10:32 AM
Rebecca Rebecca is offline
Rep: 10 Posts: 2
Jet boat won't start
Our jet boat won't fire. It turns over quite strongly, but won't fire. The gas line seems open and the spark plugs are new. Any suggestions?
Old 07-03-2006, 11:30 AM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
We can try, Rebecca. Do you have more details on the motor? What make, type, year is it? EFI or carb? How's the fuel system set up? Try the "search" button on the forun too, someone else has probably had a similar issue before. Good luck!
Old 07-03-2006, 11:52 AM
Rep: 10 Posts: 2
Jet Boat won't start
Thanks for your reply. It's a 1995 Sugar Sand Mirage with a Mercury Sport Jet engine, 120 hp, oil injection (2 stroke). I'm not sure whether it's EFI or carb. How do I know?
Old 07-03-2006, 07:35 PM
stonebreaker stonebreaker is offline
Rep: 42 Posts: 438
You need to eliminate the various systems in order to zero in on the problem. The first thing you need to do is to determine if the problem's in the ignition system or the fuel system.
Take one of the spark plug wires off a plug, stick a screw driver in it, and hold the metal part of the driver near the metal tip of the plug or the engine block. See if you get any spark when you turn the engine over. If you do, chances are it's somewhere in the fuel system. BTW, make sure you only hold the handle on the screwdriver when you do this test, or it will shock the crap out of you.
Stonebreaker
Ph.D in Redneck Engineering - Piling it higher and Deeper.
Jet, Jet Pump, Waterjet, Jet Drive vs Prop brian eiland Jet Drives 45 08-27-2010 09:04 PM
first boat.....where to start? vwaxdaus Gas Engines 8 08-12-2006 05:09 PM
first boat...... where to start? vwaxdaus Inboards 1 06-30-2006 01:37 AM
Where To Start - designing and building 22' and 24' aluminum boat Baywatch Towers Boat Design 4 04-09-2006 11:23 PM
start jet boat out of the water holdthegroove Powerboats 1 06-23-2005 11:44 PM
