Old 06-17-2009, 07:00 AM
ade843 ade843 is offline
Rep: 10 Posts: 11
Jet boat wont get up on the plane, all show no go.
Can someone please help me, i am new to boating and i have recently purchased a Jet Boat with two U.A. Jet Drives made by U.A. Eng Ltd. Over the past ten years the previous owner has converted this boat from twin engines to a 1.5 Alfa flat four unit, the engine runs sweet and is currently running ratio 1:1 from belts direct from the drive. The engine will rev to approx 6000 fine but the propulsion dosnt really seem to increase, it just seems to bury the back end and produce alot of water disturbance from the back. I am starting to think that either the gearing is incorrect or the jet drives have either air ingress or worn parts. Can someone help?
Many thanks
Sam
Old 06-17-2009, 12:44 PM
Rep: 1397 Posts: 7,215
From what you are saying there are two jets run from one engine through belts. I would say it is underpowered
Old 06-17-2009, 05:15 PM
daiquiri's Avatar
Engineering and Design
Rep: 2340 Posts: 2,472
Hello,
Can you give some more info about the boat - like model, main dimensions, weight and deadrise?
Old 06-17-2009, 05:56 PM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 1776 Posts: 2,691
ade
A jet will follow the prop cube law in terms of power, if your delivery is higher than it can absorb you have a problem; if your engine is revving higher than the jet can take, it will cavitate. You need to match the engine rpm with that of the jet.
Otherwise it is a bit like being on a bike, in say 1st gear when going down hill. You can't peddle as fast as the bikes wheels are rotating so you can't increase your speed. The bikes wheels being the jet and your feet peddling being the engine (going too fast but no delivery of power/thrust). When you select the right gear when going down hill, suddenly you get "power" back!
See the attached as a rough guide to explain further.
So you need geraing to match the jets power curve..
Old 06-17-2009, 06:00 PM
Naval Architect
Just noticed your location..where on the IoW are you?
Old 06-18-2009, 04:01 AM
Rep: 10 Posts: 11
Im in Binstead, you?
Old 06-18-2009, 04:05 AM
Rep: 10 Posts: 11
I cant tell you much, it has Almarine on the wheel. I will attach some photos of the jets. Hope this helps
Jet boat tops out engine revs without planing-dsc00401.jpg  Jet boat tops out engine revs without planing-dsc00402.jpg  Jet boat tops out engine revs without planing-dsc00403.jpg
Jet boat tops out engine revs without planing-dsc00404.jpg  Jet boat tops out engine revs without planing-dsc00405.jpg
Old 06-18-2009, 04:17 AM
Rep: 10 Posts: 11
Hello daiquiri can you explain deadrise please? I will try and get you more information later today. many thanks
Old 06-18-2009, 04:19 AM
Naval Architect
Im in Japan...but i know the IoW very well
Old 06-18-2009, 04:21 AM
Naval Architect
Deadrise is the angle the bottom hull makes with a horizontal line that intersects it.
Old 06-18-2009, 04:45 AM
Rep: 10 Posts: 11
Still not too sure, i am very new to boating. Did you use to live here then?
Old 06-18-2009, 04:54 AM
Naval Architect
ade
see this for an explanation
http://www.answers.com/topic/deadrise
yes, i grew up on the IoW, know it very very well
Old 06-18-2009, 04:55 AM
Rep: 10 Posts: 11
many thanks, where did you grow up then?
Old 06-18-2009, 08:19 AM
Rep: 10 Posts: 11
I have these pictures of the boat if it helps, its approx 16" long. Until i get home i cannot supply anymore info.
Cheers
Jet boat tops out engine revs without planing-btlsfkgcgk-kgrhgoh-dmejllluysebkhfn12-kw-_1.jpg  Jet boat tops out engine revs without planing-btlsh-q-2k-kgrhgoh-d-ejlll0oh-bkhfn915z-_1.jpg  Jet boat tops out engine revs without planing-btltnlwbmk-kgrhgoh-d4ejlll0wegbkhfqbunu-_1.jpg
Old 06-18-2009, 08:23 AM
Naval Architect
ade
Nice looking boat.
I used to live in shanklin.
I think i recognise those houses in the background!!!
Power/Resistance Calculation for Planing V-Hull & Fuel/Engine Required Kapitan_Raider Outboards 24 11-26-2008 05:34 AM
Speed and revs relationship seanform Boat Design 1 05-05-2008 02:07 AM
Penta 5.0 sx only revs to 4000 rpm LogLew Sterndrives 2 06-24-2007 12:37 PM
T-Tops ironpirate Boat Design 3 01-05-2006 10:50 AM
jet engine boat Powerboats 9 08-27-2002 10:00 AM
