Old 06-30-2006, 10:58 AM
sandrail sandrail is offline
Rep: 10 Posts: 6
jet boat drive shaft bearring
Hope everyone is having a great summer. I have a 1984 jet boat with a 350 olds And need to replace the drive shaft bearing located in the small box coming out of the engine before the jet drive . Could somebody please tell me how to replace this bearing? Do i have to remove the entire jet drive to do this or just undo four bolts on the bearing box? Thanks for any help you all have a nice day.
Old 06-30-2006, 11:14 AM
stevel stevel is offline
Lost at sea
Rep: 15 Posts: 118
What kind of jet do you have?
With all the different jets out there, I'm having a hard time picturing what you are describing. What kind of jet does your boat have?
Old 06-30-2006, 01:02 PM
Rep: 10 Posts: 6
Hi Stevel Thanks for your reply Not sure what kind of jet I have not a Berekley I am sure, it's a 1984 Challanger and right behind the flyweel the shaft coming out of engine before connecting to the jet has a 3 by 3 box housing a bearing. figure the previous owner never greased this and after about 15 minutes in water the bearing made a bad noise, we added grease "TOOK TWO SMALL TUBES and found that the box was full of water which by adding the grease pushed the water out after adding grease the sound stopped and only happens once in a great while, Have let it dry out for a month now and going to add all new grease. Do you think that short exposure to water could have ruined the bearing? Yhanks for your help. Richard
Old 06-30-2006, 01:13 PM
Lost at sea
Rep: 15 Posts: 118
Unfortunately, I'm not familiar with that setup. If I'm understanding correctly, you have a shaft going into and out of that box (engine|shaft|box o' bearing|shaft|jet drive). I'm guessing that there are some u-joints trown in there somewhere for good measure too. Is that what's inside the mystery box?
Old 06-30-2006, 04:51 PM
Rep: 10 Posts: 6
I Don'tthink so no room for u joints just as you said shaft from engine going to jet with this box between with a bearing and grease fitting. very hard to describe. What you probally do know having the knowledge you do, is do you think having that bearing,(I assume it is stlainess steel) in the water for aprox 15 minutes with no grease would ruin the bearing? That is my greatest concern, so could I just be worrying for no real reason? Thanks for all your help. Richard
Old 06-30-2006, 05:41 PM
Lost at sea
Rep: 15 Posts: 118
Probably not, but...
A brief exposure to water, followed by being filled with grease would probably do no harm. Having run it without lubrication until it makes noise may have done a lot of damage. Where did the water come from?
Jet, Jet Pump, Waterjet, Jet Drive vs Prop brian eiland Jet Drives 45 08-27-2010 08:04 PM
inflatable boat with jet drive - is that possible? DRY_GIN Boat Design 12 04-05-2006 08:46 PM
World`s First Trimable Shaft Drive. tom kane Open Discussion: All Things Boats & Boating 26 12-27-2005 06:25 PM
exhaust on a jet drive boat jetboatjill Open Discussion: All Things Boats & Boating 0 04-08-2005 05:54 PM
short shaft motor on long shaft boat ohenry Boat Design 0 03-21-2005 08:02 PM
