Old 07-23-2008, 05:50 AM
montyrosevear montyrosevear is offline
Rep: 10 Posts: 15
Jet
Hi i have a ppjet but there is no identification on it i have paired it to a nissan torreno 2.7 turbo diesal will i get the revs needed, i have been told that my jet is not a pp but made by another manufactor , this engine was paired befor i bought the boat its fitted to a 19ft fast fisher dory my problem is spare parts for the jet can any one give me any advise please i no pp jets have been taken over by Thornycroft they told me its not one of there jets as the fin on my jet is bigger then there fine when i bought the boat i was told it was a pp jet but i dont think it is so any help will be greatfally recieved thank for taking the time to read my problem.
Old 07-26-2008, 04:55 PM
anthony goodson anthony goodson is offline
Rep: 241 Posts: 391
Without a photo or more information it is impossible to help you
Old 07-17-2009, 06:39 AM
kcmd kcmd is offline
Rep: 10 Posts: 24
I hope the pics help
Old 07-17-2009, 07:24 AM
Rep: 241 Posts: 391
Hi
Looks like a PP with a larger fin grafted on . Most spares are not a problem on these ,apart from the castings. Normally the only parts that wear are bearings and seals The rear bearing should be a D U bush made by glacier bearings This should be lubricated with EP90 oil ,note the orientation of the seal The front bearing is an automotive bearing ,there are two kinds just take it to your local bearing stockist to match he will have the DU bush as well The seals are all common automotive seals again from yor bearing stockist but do note which way they are mounted when you remove them and replace the mild steel springs in the new ones with stainless,these are easily obtainable now that they are specced for the catering trade. The collett that locks the impeller to the shaft will break in time or if it is overtightened, an original was £200 or so when I last looked, but any competent machine shop can make one very easily They are made from polyacetal rod ,this can be sourced as an offcut normally or even on e-bay. do not use nylon,it looks similar but is not suitable as it absorbs water and expands
The performance of this boat is hard to judge ,it would definately benefit from a larger jet but try it first without throwing too much money at it the problem will be that jets this small are very sensative to weight and your engine and hull are at the top end of this jets capabilities
Jet, Jet Pump, Waterjet, Jet Drive vs Prop brian eiland Jet Drives 45 08-27-2010 09:04 PM
berkley jet skippers_1 Jet Drives 1 03-17-2008 07:34 PM
pp jet pricey797 Jet Drives 1 10-02-2006 06:30 AM
pp jet pricey797 Jet Drives 2 08-23-2006 09:24 AM
