Old 10-16-2006, 06:16 AM
A_Appleyard's Avatar
A_Appleyard A_Appleyard is offline
Rep: 10 Posts: 12
Info about PDX Marine Drive?
Has anyone got any images or detailed descriptions of the PDX Marine Drive (apart from the small image in http://www.pursuitdynamics.com/marine.php )?
What steering gear tends to be on a boat which has a PDX Marine Drive?
PDX say that this sort of jet drive can be steam-powered: if so, what sort and amount of noise does it make?
Is the jet unit usually mounted outside the hull, or inside with its blast end sticking out of the stern?
Old 11-06-2006, 09:11 AM
Nuba Nuba is offline
Rep: 10 Posts: 4
More PDX info
Try this link, (nifty little thing not?)
http://www.pursuitdynamics.com/downloads/annual2002.pdf
Old 11-06-2006, 10:14 AM
Rep: 10 Posts: 12
Thanks. However, my .pdf reader refused to read the images (except for the images of men's faces). The text is only a business annual report, with no text describing the PDX, and likely the PDX image is in the images that my .pdf reader refused to show. Could you possibly send me these PDX images as .JPG?
Old 11-06-2006, 11:10 AM
Rep: 10 Posts: 4
More PDX
Looking for more . . .
Old 11-06-2006, 11:22 AM
Rep: 10 Posts: 4
Reflexions
Looking at this drawing, my thoughts;
this could replace the interior of a jet drive, add a air-compressor and a steam generator . . .
steering by thrust vectoring, reverse by bucketing.
or put the complete reactiontube just below the hull, and let iet pivot around the air/steam tube ; High maneuvrebility !
Just thoughts ofcourse (excuse my bad english)
I red somewhere they found a usable steam reactor for recreational boating .
Please info in Velvet drive transmission problem MarioCoccon Sailboats 4 05-09-2009 07:08 PM
Marine & Naval Warship Design Engineering Positions - Marine Engineer - Principal Patricia56 Services & Employment 1 12-29-2006 03:29 AM
New to Boating! Restoration Project! Info on Browning Marine? mustang Fiberglass and Composite Boat Building 4 07-14-2006 10:26 PM
Stern shape design for surface drive/stern drive Alik Boat Design 8 06-15-2006 07:36 PM
Surface Drive Info jprev Powerboats 11 11-21-2004 04:57 PM
