| Impeller clearance specs on a 733 Hamilton does any body know, or know where I can get the specs on my Hamilton 733? What is the procedure to check those specs? |
| The NZ jet forum is probably a better place to ask such questions. |
| 733 or 773? Either way, impellor OD to wear ring ID shouldn't be larger than 60thou (30 thou radius / gap between). They can be rebuilt easily enough. You should notice considerable slippage as you mash the gas which'll settle a little as you gain speed (slight over-rev, then the revs drop back a little, probably still a little above normal) |
__________________ tomkane |
| Hamilton 733 3 stage questions | mrtoybox | Jet Drives | 1 | 01-27-2009 03:47 PM |
| Euro Canal Clearance | Tad | Boat Design | 5 | 11-01-2008 06:26 PM |
| Bridge-deck clearance yet again | Fanie | Sailboats | 4 | 10-26-2007 04:49 AM |
| Clearance under a bridge | solidovale | Boat Design | 2 | 07-31-2006 01:58 PM |
| sterndrive, clearance | Danielsan | Boat Design | 4 | 09-25-2005 10:03 PM |
