| How to calculate the size of small a jet drive from scratch? I am wanting to construct from scratch a small jet drive unit for a tender. I have a couple of old lawn mower engines with about 3 hp, which i am hoping to use. The tender is only 5 foot long, would only have 2 or 3 adults in. I am not after high speed, just enough to potter about my local harbour come the summer. A prop would be the obvious answer here, but my local harbour is a mud hole, and im keen to learn about jet drive systems. Where do i begin to design the system bearing in mind all that is known is the input shaft power? Im not asking for an answer, just some guidelines or pointers I can then research into. Thanks in advance. Nathan |
| Hi, Nathan, if you switch to the thread "Why a jet drive?", note #23, you will find an example of a simplified calculation procedure. There is a comparison with a propeller case included as well. |
| Jet, Jet Pump, Waterjet, Jet Drive vs Prop | brian eiland | Jet Drives | 45 | 08-27-2010 08:04 PM |
| small jet-like electric drive | DrDistorzion | Jet Drives | 14 | 08-18-2009 08:36 PM |
| jet drive for small river fishing | kenstl17 | Propulsion | 20 | 01-19-2009 09:41 PM |
| Simple jet drive for small boat | tom kane | Jet Drives | 2 | 04-01-2007 08:20 PM |
| Design issue - calculate the power requirement for 8 kn jet | Tealc | Boat Design | 14 | 04-03-2006 02:27 AM |
