Old 07-14-2009, 09:58 AM
mercedes mercedes is offline
Rep: 10 Posts: 2
HELP! Needed Cheap Impellor for PP Jet
I have a PP jet on my fonda 14'6 I need a new or second hand impellor for it the engine produces around 110bhp any ideas where I can get a cheap one? Thx. for any help
Old 07-14-2009, 11:12 AM
baeckmo baeckmo is offline
Hydrodynamics
Rep: 909 Posts: 597
You say 110 hp; at what rpms? And which PP? They are numbered according to inlet diameter; type 65 is 6,5 inch dia, 90 is 9,0 aso. Is your old one totally wrecked, ie a substantial part of blading missing or so? Otherwise, they are repairable. I have som 90 ies on the shelf here.
For new spares, contact Vosper Thornycroft, Mr Brent Voce, +44 2392 5397 50.
Old 07-14-2009, 01:34 PM
Rep: 10 Posts: 2
My pp jet is a 65 with 110 bhp at 5500 rpm.What i need is a larger impeller the engine is over revving and needs a larger impeller.The one i have is a 573,i think i need a 482. Would it be possible to exchange plus any cash difference.
Old 07-14-2009, 02:36 PM
Hydrodynamics
Rep: 909 Posts: 597
Sorry, no 65 impellers here. But if you can't localize any in GB, the one you have may be repitched. First check that there is nothing choking the inlet (plastic bags on grating, condomes on leading edges, nylon stockings around the shaft.......), plus check tip clearance. You run a gas engine I guess, what max revs (and what boat speed) d'yo get now?
Old 07-14-2009, 06:53 PM
anthony goodson anthony goodson is offline
Rep: 241 Posts: 391
Also check for air leaks around transom seal and handhole cover,
Swedish boating sounds far more colourful than it is here ,doesn't it
Old 07-14-2009, 07:33 PM
Hydrodynamics
Rep: 909 Posts: 597
You'd be surprised to see what comes drifting to our waters with the west winds from, well you know where......
Jet, Jet Pump, Waterjet, Jet Drive vs Prop brian eiland Jet Drives 45 08-27-2010 09:04 PM
Cheap to run, cheap to build electro plywood cruiser ? ASM Boat Design 72 08-08-2008 10:13 AM
jet pump needed run off 300cc 2 stroke madtech Jet Drives 0 05-10-2007 04:58 PM
Outboard jet impellor pitch to HP ratio? dreadnought Jet Drives 7 04-10-2007 10:29 AM
Jet Boat Restore: moral support needed. spoolin'up Boatbuilding 7 08-05-2005 09:39 PM
