| Fonda Jet Drive Engine Linkage Hi all I've just acquired a Fonda jet boat (previous owners project) and am in the the process of rebuilding it. Unfortunatly the previous owner was not the greatest of engineers and has bodged quite a few things ![]() The question i have is: How is the engine usually connected to the jet drive? At the moment the linkage is made with a single UJ (engine is a 3.5 Rover V8) this seems a little dodgy to me as it will allow for no angular missalignment which will happen when the engine rock on its mounts! If anyone with a similiar boat could tell me of how theirs is constructed i would appreciate it (may be i'm just be overly fussy - i just don't want it to break when i'm several miles from shore!!!) Thanks. Ian |
| Hi Ian, I have a fonda jet boat driven by a 3.0L Ford V6 engine the jet drive is coupled to the crank shaft of the engine via a rubber coupling. The rubber prevents the engine vibration being transmitted down into the drive. What sort of a drive unit do you have? I am currently having problems with mine trying to source parts but not having much luck. Martin.. |
| Ian, I'm at the point of trying to design my coupling for a rover V8 to hamilton jet drive and I would have the same reservations with using a single UJ coupling especially without any rubber torsional dampener. Have a look at the Ultrajet site www.ultradynamics.com it's very comprehensive on many different topics, incl couplings and alignment. I found it very useful. Regards Paul. p.s. Let me know how you get on. Cheers. |
| DateLine bikini shaft coupling The boat is having its engine replaced and we need to replace the flexible rubber drive coupling, can any one tell me where we can get a suitable replacement for a dateline bikini(ford v6, jet drive unknown but has west end written on it). Thanks in advance, Will |
| Typically, here in the us, you hook the jet to the engine using what's know as an "H-Bar". Here a link to a selection of them. http://www.cpperformance.com/product...nes/h-bars.htm Hope this helps. -jim lee |
| Jet, Jet Pump, Waterjet, Jet Drive vs Prop | brian eiland | Jet Drives | 45 | 08-27-2010 09:04 PM |
| jet drive | Joinery Designs | Propulsion | 1 | 04-11-2008 08:31 PM |
| Fonda Jet Drive | martin mc | Jet Drives | 22 | 06-12-2006 10:05 AM |
| Jet Drive | CMP | Marketplace | 20 | 02-28-2006 08:38 AM |
| Jet drive? | Danielsan | Propulsion | 8 | 02-09-2005 05:21 PM |
