Old 03-25-2009, 05:50 AM
montyrosevear montyrosevear is offline
Rep: 10 Posts: 15
engine to jet drive
I have a nissan 2.7 turbo fitted to my boat on to a replica pp jet , Now can any one tell me if its possable to fit other jet drives , the drive i have is jet in board has a spline male, to a female spline reciever to rubber couplings to a short shaft to the flywheel i was wondering do all jet drives have splines i dont no never seen any other jet any imformation will be a big help guys thanks for you time.
Old 03-25-2009, 02:18 PM
CDK's Avatar
CDK CDK is offline
experimental engineer
Rep: 1316 Posts: 2,144
Berkeley, Jacuzzi and American Turbine jets all have the same SAE splined shaft. There also is a double universal joint that fits these shafts; on the input side it has a 4-hole flange.
For sizes and prices see the Glen-L-marine website.
Old 04-17-2009, 06:22 PM
speedboats's Avatar
speedboats speedboats is offline
Rep: 124 Posts: 116
The picture of the 4.0L Toyota / Lexus V8 motor shows a very common Hardie Spicer type universal coupling.
The 3.8L V6 motor shows an adaptor attached to the crank (through the flywheel) with the 4 bolt PCD and spogot machined in for the universal couple.
The SDM 200 pump (blue jet pump) shows an alternative end to a jet shaft. This is very common through-out the SDM range, and older Hamilton product (750 series and older). This type need a flange at both ends of the universal couple, and has the sliding spline in the middle. It is slightly longer overall compared to the universal with the yoke at one end.
The last picture shows the minimum distance required by the double flange type uni shaft.
engine to jet drive-dsc02002-1.jpg  engine to jet drive-dsc02406-1.jpg  engine to jet drive-dsc02598-1.jpg
Old 04-23-2009, 02:57 AM
speedboats's Avatar
Rep: 124 Posts: 116
Found some better pics showing the driveshaft, adaptor block and flywheel. Both motors are a 1UZFE (4.0L Toyota / Lexus), one coupled to an American Turbine the other to a Scott Junoir 7 1/2" pump.
Jet, Jet Pump, Waterjet, Jet Drive vs Prop brian eiland Jet Drives 45 08-27-2010 09:04 PM
pp jet drive compatable engine? chappers69 Projects & Proposals 6 01-28-2009 03:56 PM
Adapting any jet engine to propeller drive RatliffFranklin Boat Design 29 02-10-2008 10:53 PM
jet drive and engine for tender ars-technica Jet Drives 7 04-20-2007 10:32 AM
Fonda Jet Drive Engine Linkage ijw1234 Jet Drives 4 02-20-2007 08:45 PM
