Old 09-28-2006, 05:34 PM
LSU SolarSplash LSU SolarSplash is offline
Rep: 10 Posts: 8
Electric Jet Drive
Okay. You may be asking yourself, "Why the hell would you want an electric jet drive?" Well, I'll tell you. I'm a senior in mechanical engineering at Louisiana State University. For my senior project, my team will be taking part in Solar Splash 2007. This is a nationwide competition, where teams build solar powered boats and compete in a number of races. You can check it out at www.solarsplash.com.
So, one of our first goals is to look at propulsion systems. We have to consider jet drives and conventional prop drive systems. It would be greatly appreciated if anyone with something of a knowledge of jet drives could help us understand the efficiencies and design of these systems. Thanks beforehand for your help.
Old 09-28-2006, 05:51 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
Hi LSU,
In general, jet drives have pretty poor efficiency at low speeds. Where they excel is in craft that operate over 20-25 knots or so.
In a solar powered craft of any kind, efficiency is paramount. So is weight, by the way. A jet unit is a lot heavier than a conventional prop driven system.
So yes, look into the jet option, but I'm pretty sure if you do all the math, you'll end up with the largest diameter propeller you can fit.
Old 09-29-2006, 03:32 AM
Crag Cay Crag Cay is offline
Rep: 547 Posts: 629
Jet drives also allow the engine to run at optimum revs with the boat speed controlled by the bucket when necessary. But an electric motor develops full torque at all revs so is a better match to a standard propellor anyway.
I think just comparing water jets with props is a waste of time. I think the disadvantages for you of a water jet can be taken as a 'given'. You might be better off using your research time figuring out how to get the cleanest flow of water to your prop. There is some development afoot into hubless props in ducts, but you also need to investigate conventional shrouds, or putting the prop at the bow, or....
Old 09-29-2006, 09:32 AM
Rep: 10 Posts: 8
Thanks a lot for the replies. That pretty much coincides with the information that I've found online. In our case, low speed performance will be critical. Acceleration is obviously important in any kind race. I do think we will end up giong with a shrouded prop design, which means we get design our own lower unit. That should be fun.
Jet, Jet Pump, Waterjet, Jet Drive vs Prop brian eiland Jet Drives 45 08-27-2010 09:04 PM
Electric Jet Ski Conversion glines Propulsion 44 07-17-2010 09:41 AM
LPG Generator - Electric Motor Drive NB Willawaw Propulsion 1 12-22-2005 06:00 AM
Concept electric drive duluthboats Propulsion 46 07-08-2005 08:27 PM
Diesel jet drive or electric I/O? MedicineMan Powerboats 4 04-23-2004 12:48 AM
