| dual jet drive bottom layout i'm placing jet drives in drawings, one drive usually sits in flat triangle rite? now two drives i'm not sure, ok they better come down much as possible to the center but do they cant as in pic? to top it off, how should it look in a transverse stepped hull when they hit the step as shown in pdf |
| The intake body shown (is that Alamarin?) has a V-shape forward of the inlet grating. For double installation that must be trimmed down to suit eventual bottom curvature. Note that the cl of the intake opening must follow the buttock line, which means that the engine cl is NOT parallell to keel (engine fronts stand closer than their aft ends), due to the shaft inclination! There may not be any longitudinal spray strakes or steps inside the buttock line just outside the intake body, nor any transverse steps. Also no through hull fittings like water intakes or outlets, logs or equivalent, in the bottom area in front of the inlet. If I understand your dwg, you intend to install the jets outside the longitudinal step?? If so, forget it! The aeration from the spray crossing the step will cause a complete loss of pumping power. Those waterjet pumps can only handle about 5 percent of air volume in the inlet; so take all steps possible to avoid air following the bottom into the intake. Even deadrise angles less than ~10 degrees should be avoided for this reason. |
| yipster, Why two jet drives? -Tom |
| Twin jets in a V-hull is asking for trouble. Believe me, I've been there. Unless you can obtain or make adapters to mount the jets horizontally above the inclined intake grate, you'll have insufficient clearance for the lower engine parts. Obtaining a vertical steering axis by rotating the nozzle heads and drilling new holes may be a solution but only if the flanges are cylindrical. And as Baeckmo pointed out, the presence of air will degrade the performance beyond the point of usefulness. |
| thanks for the pro help and advice gentleman ! |
| altho my first thought too, to answer your question Tom: i am asked to do so and these reply's do shine light so thanks again, marry xmas and a happy new year |
| Ahhh, a customer request, I get it, "No correlation between brains and money." Thanks for the reply. All the best to you, Tom |
| Is there any spec saying how far apart the two have to be? About 8 years ago there was a legal battle between, I think Aggressor and another group over a dual jet design. I saw the "other" one, forgot who, run their machine. It worked ok I guess, but not all that hot. I recall that both jets bolted to the same intake casting. One engine and gearbox. Something like that may help get around your mid hull problem. I really wonder why they think dual jets would be a good idea. -jim lee |
| oops Tom, was gonna mention something similar and not just becouse i linked "No correlation between brains and money." to this thread guess its meant as "top of the line" rib drive setup. interesting as it may be i figger this hull suits dual surface drives better on the other hand i still have, reading anthony's post above the boat may well be for people in the water, oops |
| Lots said that two jets are bad but nothing about why two jets are bad. Is it just that they are set up for singles or is there something you believe to be inherantly bad? |
| I think the logic goes something like this ,if you have had a bad experience with a jet drive ,through no fault of your own ,which many people have ,then jets are bad ,and if one jet is bad then it follows that two jets must be twice as bad. |
| Not necessarily true Anthony. I've had very bad and costly experiences with twin jets, absolutely my own fault because in a moment of weakness I believed the text of a Californian website. Yet for a rescue vessel that must be able to cope with impossible conditions, twin jets seems a good idea even to me. I would use diesel engines though. |
| CDK you have taken my post too literally,it was written tongue firmly in cheek. I am of course aware of your problems with jets from your previous posts and have every sympathy with your feelings about them .As I have said here many times the people who have been to blame for the bad reputation that jets enjoy,are ,with a few exceptions the manufacturers themselves but I feel that things are improving in this regard ,shared information on forums like this one helps a lot. A correctly specified jet will work very well in certain roles ,but these roles are limited and specific, in the best case scenario they are unrivalled in the worst they are next to useless. Now to attempt to answer the man's question with my tongue out of my cheek, there is nothing inherently bad about twin jets in the right application ,in the smaller vessels we are talking about numerous lifeboats and safety boats use them and there are two outstanding military examples that come to mind The British CSB and the American PBR which created its own legend in the Vietnam war Merry Christmas |
| Would be interesting to have baeckmos comment again. Richard |
| Jet, Jet Pump, Waterjet, Jet Drive vs Prop | brian eiland | Jet Drives | 45 | 08-27-2010 08:04 PM |
| Converting from Jet drive to Stern drive | gearhead496 | Boat Design | 9 | 03-22-2008 11:23 AM |
| Dual Sport Jet | JP Marine | Boat Design | 1 | 01-04-2008 02:00 PM |
| jet drive on flat bottom | Rusty Bucket | Jet Drives | 5 | 05-11-2007 12:17 AM |
| Questions regarding an unorthodox drive layout. | Ji Simmons | Boatbuilding | 2 | 08-11-2004 02:41 PM |
