Old 09-13-2009, 12:31 AM
KiwiFabricator KiwiFabricator is offline
desigh suggestions for 12'6 jet
I have a 12'6" shallow vee gullwing hull glasscraft (built christchurch NZ in the 70's)
have removed 50hp redband merc outboard and now purchased a "wetjet" single stage apparently from a 800cc 110hp jetski.
i am looking to repower the boat with either a mazda or toyota 1600cc EFI twincam as these are cheap and plentiful in NZ and i can do all the marinisation myself -- the boat is glass in construction with 3/4" timber framing and a full 12mm ply floor glasssed in - as a boatbuilder/fabricator i have no issues fitting the motor and jet unit but just looking for some advice as far as how far to mount jet nozzle from back of boat,etc and what to watch out for -- im finding it quite hard to find info on how to retrofit a jet into a previously outboard powered boat
any idea what sort of performance to expect and is my motor choice within reason??
pics of boat as it is are coming
any help would be appreciated
cheers
Old 09-18-2009, 11:16 PM
speedboats's Avatar
speedboats speedboats is offline
Rep: 124 Posts: 116
The 1600cc engine probably won't rev high enough for a jet ski jet pump. I think I saw a Coggan jet on TM which would be more suitable for that engine, or alternatly if you want to stay with the pump you have then try looking at an engine out of a larger motorcycle.
The mods to the hull are simple but important, we await the pics with interest
Old 09-19-2009, 12:26 AM
pistnbroke's Avatar
I try
Rep: 372 Posts: 1,230
What revs did the 800cc unit do thats the question ...you can move your engine forwards on a driveshaft for balance. Car engines are not rated to be run flat out for long eriods ...maybe rated for 25 % so there is another problem
I have done the opposite on my jetski ...taken the jet unit out and fitted an outboard
Old 10-08-2009, 03:38 AM
MadScience_7 MadScience_7 is offline
If you want a small lightweight engine that likes high RPMs, look into the Mazda rotary. A naturally aspirated 13B can make 150HP and hold it at 6K RPMs just fine as long as you have adequate cooling. If you need more power than that a turbo can bump it up to 250 pretty reliably. A complete long block is under 400lbs. They're also used a lot in homebuilt airplanes.
Old 10-14-2009, 08:04 AM
Gerald Gerald is offline
Rep: 10 Posts: 12
I am working on a similar project using a newly designed hull. It seems to me that if the Toyota can run all day long at 3,500 rpms and we put attach a 2-1 gear box we would be in the range of a wot jetski motor?
In addition to that, jet skis use a 140 or 155 mm dia. pump for a bunch of different motors, All the same diameter impeller but the HP ratings jump from 90 up to 255. That would indicate to me that they change the impeller degrees as HP goes up or down. Let´s say that your motor puts out 100 HP at 4,000 rpm and the jet ski motor puts out 150 at 6,000. With that in mind it might be fair to say that the jet ski puts out 100 hp at 4,000. That seems to be apples to apples. You just won´t go as fast but your jet drive sure will not know the difference.
Here is a utube site where the guy used a VW 1.9 turbo with a jet ski drive.
http://www.youtube.com/watch?v=OnjlnEBtqv4
Gerald
Old 10-14-2009, 08:14 AM
Rep: 10 Posts: 12
Here is antoher site you might find interesting. http://www.rjet.com.br/funcionamento.html
These guys are located near me. They have attached several different car engines to thier jets. Look at clients on the top line of the site to see them or click on rjet in utube.
Gerald
Old 10-14-2009, 09:20 AM
sabahcat's Avatar
sabahcat sabahcat is offline
Rep: 224 Posts: 708
How retro
http://www.svensons.com/boat/?p=Mech...rated/Aquarail
Old 11-02-2009, 10:48 PM
jbm jbm is offline
Rep: 10 Posts: 13
we have run the weber mpe 750
they will rev higher for you if you are going with a jet ski type pump
we are using a scott 7.5 " pump and custom impeller at 7000 rpm
Jet, Jet Pump, Waterjet, Jet Drive vs Prop brian eiland Jet Drives 45 08-27-2010 09:04 PM
Looking for Suggestions Sands Boat Design 15 01-23-2006 09:25 AM
Suggestions are welcome!! pbrito Sailboats 7 09-20-2003 03:20 AM
