#31
| Ahhh, V8 torque and soft suspension, those were the days! -Tom |
#32
| LOL Tom, probably why the old hands doesn't get sea sick so easily, them cars felt like boats on water ![]() Still, nothing like a V8 eh. Pity about fuel being expensive and going scarce. I bet the next form of propulsion isn't going to sound like that, so better record some sounds while we have them.
#33
| Your right about the inertia. I read that in the Military section on Jet drives. Without the stator the whole boat would tip. There were other Hydro-dynamics the Stator took care of as well. The output would be going out in a Scatterd mess, but the stator aligns the output to make it smooth, taking some of the resistance out of the ehausting water. |
#34
| *Sigh* Yes Thuddy, if only my wife thinks I'm right a couple of times eh ![]()
#35
| There aint enough Wisdom in the world to help you with that problem. |
#36
| The stators need to run between the multi-stage impellors to 'straighten' the water flow so the next impellor can get a good 'bite', else the water inside the pump would end up rotating at next to the same speed as the impellor so the last one would do nothing |
#37
| Yes, that's what I read. Also, though I didn't see it, I'm thinking the stator angles between Props were different than the last stator angle that wants to straighten out the flow. On the number of Stages: Wouldn't it be better to have a single stage rather than multiples? There must be a reason for Multiples? |
#38
| You can only achieve a certain pressure increase (=velocity increase) per stage, basically depending on impeller outlet peripheral speed. If you design the nozzle velocity (vj in my earlier text) above this limit; then you have to add another stage in series, just like we do in any other kind of rotodynamic pump. And yes, a single stage, giving a high flow rate is generally better efficiency-wise, than a low flow - high velocity, multiple stage unit. It is all a question on finding the best balance between pump hydromechanical efficiency, the impulse efficiency and possible power density of the pump design elements. |
#39
| Holy Cow, do I dont remember a lot! Although I never got as far as Hydraulics. It's good to know we have PhD's when we need them. Thank's y'all. |
#40
Thanks Hoyt !
#41
| I heard the weather is wet in Safrica. How much more water do you need for a jet drive?
__________________ Hoyt "Lightning is very selective and will not strike crap." Wynand N "We Redistribute World's Wealth By Climate Policy" UN IPCC Official Last edited by hoytedow : 01-14-2011 at 11:56 AM. Reason: to stay on topic |
#42
| SA is a water poor country. I'll only admit to enough rainfall when there's more boats (with jet drives to stay on topic ) than cars here ![]() Seems the whole world is suddenly getting more rain, there's floods in a lot of places.
| Small Jet Drives | thesuit | Jet Drives | 3 | 10-27-2010 08:38 PM |
| jet drives | ed fitz | Jet Drives | 0 | 07-08-2010 09:53 AM |
| Question about jet drives | boatnewb | Jet Drives | 5 | 10-21-2009 05:20 PM |
| OB jet drives | ted655 | Outboards | 2 | 01-11-2007 08:38 PM |
| Props vs Jet drives | 67-LS1 | Powerboats | 3 | 11-23-2004 03:45 AM |
