Old 06-09-2009, 12:31 PM
fnr1011 fnr1011 is offline
Converting Yamaha Traditional Prop to Jet Drive
I have a 2004 Yamaha 115 HP prop engine. I am considering converting it to a jet drive. Does anyone know how much trouble it is, what are the pros and cons of doing it, and what the approximate costs might be to do it. Thanks a lot.
Old 06-23-2009, 04:42 PM
ondarvr ondarvr is offline
Rep: 78 Posts: 383
The switch is easy, the cost will be around $2,000.00 for the pump.
Pros... no prop to ding, safer, shallow water is no problem.
Cons... 30+% loss of power, fuel consumption goes up by the same amount or more, need to change the transom height (taller), it will suck up anything in the water (weeds, a leaf, rocks, sand) and can become plugged up.
I run shallow rocky rivers and there’s no way to get around without a jet pump, but if I didn’t need one, I’d run a prop all the time.
Jet, Jet Pump, Waterjet, Jet Drive vs Prop brian eiland Jet Drives 25 06-20-2008 04:23 PM
converting v-drive to stern drive? tentantoes Sterndrives 4 06-13-2008 09:54 AM
Converting from Jet drive to Stern drive gearhead496 Boat Design 9 03-22-2008 11:23 AM
yamaha F15 prop htdawg Outboards 0 07-25-2006 01:32 PM
jet drive v/s prop. big cat Boat Design 8 05-19-2003 09:08 PM
