| can i run a berkley jet out of the water? Hi, does anyone know if it will harm a berley jet unit to be run out of the water ? is there a way to hook up a garden hose to run it? |
| Safest bet would be to call the manufacturer or a local dealer/service. Lurvio
__________________ Hopefully creating something useful, since 1983. |
| Yes, a Berkeley jet can run dry, there is nothing in it that needs to be wet. But you have to provide water to the engine behind it by removing the supply hose from the pump body and hooking up a garden hose.
| Berkeley jet. Thanks for that info, that makes it nice and easy, Jim. |
| The rope seal on the mainshaft will need water for lubrication at high rpm or extended dry running, especially if they have been over-tightened, as they usually are. |
| I wouldn't. At least shoot a garden hose in there. -jim lee |
| berkley jet | skippers_1 | Jet Drives | 1 | 03-17-2008 06:34 PM |
| What to look for in a "Used" jet/pump, so as to not end up w/ a useless Berkley? | colbytcheese | Jet Drives | 4 | 02-07-2008 06:57 AM |
| jet pump needed run off 300cc 2 stroke | madtech | Jet Drives | 0 | 05-10-2007 03:58 PM |
| Water jet | Wellydeckhand | Powerboats | 7 | 05-11-2006 07:39 AM |
| Berkley Jet Drive Inspection? | sjohns4 | Propulsion | 1 | 07-04-2005 11:20 PM |
