| Berkeley drive with bronze impeller problem I replaced my aluminum impeller with a bronze one and now I get a lot of rattling or chatter noise in idle speed. The bronze one weighs 10 pounds more than the aluminum one. It sounds like the noise is coming from the thrust bearing area. I always had an occasional backlash noise with a real slow engine idle. Is this noise a indication the bearing is going bad or is the weight of the bronze impeller causing this. I put the aluminum impeller back in and the noise went away. Any help with this problem would be appreciated. |
| Why would you want a bronze impeller? How muchhorsepower are you running? Also, try asking the same question here: www.banderlog.com -jim lee |
| About 330 HP. I use the boat in salt water. |
| WANTED... Berkeley jet drive 5j5... | wingnut2840 | Jet Drives | 11 | 07-01-2009 09:36 AM |
| Impeller and jet drive basics | ginger wizard | Jet Drives | 1 | 11-27-2007 04:08 PM |
| mercruiser out drive reverse problem | badbowtie | Powerboats | 1 | 05-29-2007 02:43 PM |
| Merc Stern Drive Problem | Jim Donati | Sterndrives | 4 | 11-27-2006 08:30 PM |
| Berkeley jet drive clearances | user1636 | Powerboats | 0 | 05-07-2006 07:21 AM |
