| BBC to berkely jet pump water hose plumbing configurations I have a 454 BBC using a 1981 Berkeley jet pump drive. I have had 5 boats and this is my first jet boat. I have rebuilt this and would like to know the correct water hose plumbing configuration. Is the water fed from the jet pump.. to each exhaust at 1 of the 2 front water ports? Then from the other front water port to where a engine water pump would be? Then out the thermostat housing back to the rear water port on the exhaust manifolds? Does anyone have a diagram or can you explain it to me? I am racetucker1@yahoo.com. Thank you for this forum. |
| You have it pretty much correct. Water goes from pump, through a valve, into the exhaust "logs" to preheat, from there into front of engine, out thermostat port through the "snails" on the end of the exhaust "logs". Now, do NOT put in a thermostat. Not even one of them fancy jet boat bypass ones. The normal automotive ones will blow the cooling water through all your gaskets, the jet boat ones can eventually lead to cracked heads. How to adjust jet boat cooling: Remember the valve, gate or ball, between the pump and the logs? This is your adjustment. Open it up and idle your motor in the lake. Set it at idle as hot as you are comfortable with. Once you are happy with you idle temp, you are done. When you mash the gas, the engine will get a lot cooler, don't worry, this is normal and won't hurt it. Enjoy! -jim lee |
| Water Pump as a Jet Drive | Fanie | Propulsion | 18 | 01-20-2011 04:34 AM |
| newbie jet plumbing help | v8blast | Jet Drives | 2 | 01-08-2011 01:59 PM |
| Rebuilding a 350 small block with Berkely jet | ejkob | Jet Drives | 1 | 03-27-2008 11:27 PM |
| Mercruiser 3.0 water inlet hose connector help | asiatel | Sterndrives | 2 | 05-13-2007 04:18 PM |
| 460 water hose diagram . | Sagabu | Powerboats | 1 | 12-21-2005 01:40 PM |
