| Swept forward keel Anybody knows about studies or thesis on swept forward keels? |
| I've only seen them in model sailboats, the kind that actually sail, in the 70's. There were claims of better speed.
__________________ Gonzo |
| thanks. I found this pic, but nothing about studies on this kind of fins... http://www.sailinganarchy.com/fringe...eel%20mini.jpg |
We also have such keel on 6.3m boat (see picture). Later they modified into almost straight keels on both boats. Besides designed more than 10 years ago, both of them are very competitive racers in their area. Research of these keels is presented in Larsson's book, there is a graph showing optimum sweep. |
| Search Seahorse magazine for design comment on the Australian designer John Swarbrick...Z Keel...VO60...TOKIO. Several articles were run |
FYI: Vane boats are match raced round robin style, one beat and one run against each competitor. 3 points for winning the beat, two for winning the run. The attached picture shows two vane steered 36 inch restricted class boats sailing at Central Park, New York City. This was taken during the UK/USA Challenge Cup regatta this Fall. The US team won, for the first time in six tries. Cheers, Earl |
| You need to watch very carefully here because there are lots of studies, each looking at some different effect of sweep and taper. It is important to keep in mind that Sweep is defined by the 1/4 cord line, not the foil shape. Almost all modern foils have forward sweep (-4 to -7 degrees) and sufficiant taper (40-60%) to avoid root stagnation, flutter, and structural issues but the leading edge will not angle forward. Any foil in which the LE angles forward is not optimumly loaded and is designed for other conditions. See Figure 134 and section 14, chapter 9 (volume III) of PNA and both Heorner and Marchaj devote considerable space to sweep and taper interactions.
__________________ A vessel is nothing but a bunch of opinions and compromises held together by the faith of the builders and engineers that they did it correctly. Therefor the only thing a Naval Architect has to sell is his opinion. |
| As jehardiman mentioned sweep angle in the aerodynamic/hydrodynamic community is conventionally measured at the 1/4 chord line. But I've seen some writings on boat design which use the leading edge angle which can be confusing. Too much forward sweep with insufficient bending and torsional stiffness can lead to divergence where the foil twists and bends a little which causes a moment which leads to a larger twist and moment which causes a ..... Not a good situation.
__________________ David Cockey |
Was minimizing the induced drag a major factor in selecting the angle of forward sweep, or is it just coincidental that other considerations dictated a similar angle? |
| Another factor was arrangement and comfortable entrance to cabin - the keel trunk is in cockpit while the CG and CLR are in proper positions.
__________________ http://albatrossdesign.livejournal.com |
| Forward sweep. Placing the bulb in location. Moving the ce of keel aft, for balance between the hull and the rig. Making the keel removable from the cockpit. |
| Forward Keel Location & Angle Questions | viking north | Boat Design | 14 | 04-10-2011 08:59 AM |
| Forward swept keels | idkfa | Boat Design | 11 | 03-09-2010 02:54 PM |
| Loads for swept spreader rig | Guest | Boat Design | 29 | 08-24-2008 06:05 PM |
| Forward angled bulb keel | waterworld | Sailboats | 3 | 10-26-2007 07:07 PM |
| How to find angle for swept back spreaders | kevinmal | Sailboats | 1 | 02-06-2006 05:13 PM |
