The newest and only cat under 20' to utilize a refined version the foil system pioneered in the 34th Americas Cup-The Flying Phantom is now in production.
A detailed thread on the boat is here:
http://www.boatdesign.net/forums/multihulls/flying-phantom-f-18-catamaran-43898.html
The foil system is characterized by a single main foil(windward foil retracted) and two rudder t-foils. The foil is very similar to the TNZ foil in the sketch below and has the characteristic of automatic altitude control through a large range of speeds which results in excellent heave stability/ride height control. In my opinion, the altitude control appears to be at least as good as a wand controlled system. When required, the angle of incidence of the main foil can be adjusted under sail. The foil is a sort of hybrid surface piercing foil and fully submerged "V" foil with great heave and pitch stability under sail.
Pictures-Left, sketch by DL 2012, Right-sketch by Dario Valenza 2013- The curved part of the vertical foil acts as a surface piercing foil creating less lift the more it rises. The "up-tip" "V" foil (a closed version of an "L" foil) has more drag than a "pure" "L" foil but has proven to have significantly better heave stability which is why TNZ , Groupama and the Flying Phantom use it. Hydros used a version of the system but had a much more "open" main foil with the result that it had poor heave stability and required frequent angle of incidence(rake) adjustment. Oracles main foil was closer to Hydros than to Groupama or TNZ. Leeway plays a major role in how the foil works, since it causes an increase in pressure on the low pressure side of the "L" part of the foil reducing lift as the foil rises. A small down side to a more "up-tip" closed foil is that the "L" portion of the "V" has a component of lift to leeward. The tip of the foil can also breach the surface as a backup and interesingly there is no catastrophic loss of lift as a result-the boat just settles down gently. The foil requires some degree of manual angle of incidence control but the more "V" there is, the longer the interval between the AOI adjustment required. This type of foil and the three foil configuration(single main foil and two rudder t-foils) are the major breakthrus of the 34th AC development and were used in the LAC (Groupama), and now on the Flying Phantom and the GC 32 soon to be equipped with them-pictures coming in January 2014.
