Go Back   Boat Design Forums > Design > Hydrodynamics and Aerodynamics
  #466
Old 11-27-2011, 07:07 AM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
Originally Posted by P Flados View Post
Most airplanes use flaps only to generate extra lift at takeoff / landing where they can tolerate much higher drag.
Just for general info - one of the most important functions of airplane flaps is to allow a steeper (up to 10°-12° more than a clean wing) and slower approach path during landing. That is made possible because of the combined effect of high lift and much lower L/D ratio of the wing with fully extended flaps.
Cheers
  #467
Old 11-27-2011, 08:07 AM
brian eiland's Avatar
Rep: 1577 Posts: 2,737
Originally Posted by sharpii2 View Post
In my last comment, I was trying to say that the mast on a mast aft rig must be some distance from the very aft end of the boat for the back stays to have enough leverage to resist the head stay tension, even if the back stay only goes halfway up the mast.
And, if it does go only halfway up the mast, an upper back stay is required, along with a spreader, to hold the top of the mast back.
Once you have all that rigging aft the mast, you can not hang any kind of a sail there. So, to get adequate sail area you have to go higher.
On my aft-mast design I was able to put a mizzen sail on one of my primary backstays (the one that goes down to the base upon which the mast is stepped). That was better in my opinion that having that mizzen sail blanketed by a mast itself.
I am not knocking the aft mast rig here. It is one of Phil Bolger's favorite rigs, especially for ocean going boats. All I'm saying is Mr. White's rig allows a mizzen sail hung from the mizzen mast, where the mast aft rig doesn't.
I don't think Chris has any intentions of placing a mizzen sail on that aft mast of his.
I might add here that stay sail schooners have been around for a long time. This is the first stay sail ketch I have ever heard of. Having the shorter mast aft allows better back stay geometry for both masts.
One of my original inspirations for the aft-mast design of mine was an experiment carried out on a Morgan Out Island ketch, where the traditional mainsail was removed and a staysail (might be termed a mizzen staysail) substituted in that area
http://www.runningtideyachts.com/sail/
"I once had a copy of a test on a Morgan 41' Out Island ketch , where upon removing the mainsail, the boat lost only 1/2 knot of speed, but cut its leeway in half (from 11 to 6 degrees). A staysail was then rigged between the masts in place of the mainsail, and the boat regained 1 knot of speed while retaining its decreased leeway."
I think there are a number of other examples here:
Main-less rig
As for the wing masts, I have no idea what he is trying to do. Perhaps he is trying to cut down mast drag. I think they are a bad idea on a boat that can flip. Just my opinion.
He is looking for more efficiency from a lower aspect sail plane, along with total feathering of those mast shapes without 'reefing' them.
Anything that is intricate and complex is bound to fail in the worst conditions. If it fails to feather in a storm, the boat and crew are in great jeopardy. I would go with a round mast section and a tear drop section mast sock. It's not as good as a real airfoil section, but it's a lot better than a plain round or oval mast section. And it can be pulled down, if it misbehaves.
I believe he is utilizing round section mast shapes hidden inside the foil shapes, and those outer foils are free to rotate 360 degrees so they are not venerable to worst conditions.
For the Chris White boat, his web page is a bit confusing but it would seem he is using of a inner (probably round) structural element (mast / spar) with an exterior that provides a wing with flap. The round spar as a main structural element has been used quite a bit and allows for easy construction of a very strong element.
  #468
Old 11-27-2011, 10:36 PM
Paul Scott Paul Scott is offline
Rep: 84 Posts: 272
My post about -aoa giving lift was intended to beg the question about coming away from a dock with an on dock breeze.
Also, would a -aoa + lift mast section develop enough circulation to be of interest to a jib set in front of it? Especially if there was less drag than a mast with mainsail?
Paul
  #469
Old 11-28-2011, 12:30 AM
tspeer tspeer is offline
Rep: 1395 Posts: 1,537
Originally Posted by blisspacket View Post
...And I purely can't fathom that Chris White penned the optimistic lines that would have the cat sailing sideways off the dock with an on-dock breeze, by setting each mastfoil to lift to windward.
You're not the only one.
The wings can be useful for springing off the dock in a crosswind, producing forward or aft thrust to push against a spring line to rotate the boat away from the dock. However, in this case the force pushing the boat into the wind comes from it pressing against the dock. But there's no way the wings can pull the boat into the wind without any other outside interaction.
Tom Speer
  #470
Old 11-28-2011, 12:46 AM
Originally Posted by Paul Scott View Post
...Also, would a -aoa + lift mast section develop enough circulation to be of interest to a jib set in front of it? Especially if there was less drag than a mast with mainsail?
I'm not sure what you mean by "-aoa + lift mast section", but the influence of the wing on the jib will be similar to a mainsail producing the same spanwise lift distribution. The main difference is the lift on the wing is produced further forward and may make the jib act as though it has more overlap than it actually does.
There's a widespread misconception that jibs are more effective per square meter than mainsails because they are staysails and not mast-mounted. This leads to the conclusion that one should remove the mainsail and concentrate the area in the jib.
Instead, it's the case that the jib benefits from favorable interference from the mainsail, and the mainsail sacrifices lift because of interference from the jib. But the combination of the two is better than either one alone. If you remove the mainsail, the superiority of the jib disappears. If you remove the jib, the mainsail looks better. This is why development classes that only limit sail area and make no distinction as to how the area is used (A & C class catamarans, for example) evolve to cat rigs, not mast-aft rigs.
Tom Speer
  #471
Old 11-28-2011, 08:27 AM
Rep: 84 Posts: 272
Tom, I meant this by -aoa +lift (just as an example, first one I found, no editing, I'm sure there are better ones, don't know if it would generate enough lift to get off a dock when pinned):
http://www.worldofkrauss.com/foils/784
Sorry for confusion. Low battery. Race against current, as it were.
Paul
  #472
Old 04-03-2012, 01:26 PM
Biplane Wing for Supersonic Flight
...this could upset the apple cart in understanding aerodynamics of flight...or at least show there are some 'unexplained phenomena' with dealing with these subjects
Cheaper, quieter, and fuel-efficient biplanes could put supersonic travel on the horizon, according to MIT engineers.
By Jennifer Chu, MIT
For 27 years, the Concorde provided its passengers with a rare luxury: time saved. For a pricey fare, the sleek supersonic jet ferried its ticketholders from New York to Paris in a mere three-and-a-half hours – just enough time for a nap and an aperitif. Over the years, expensive tickets, high fuel costs, limited seating and noise disruption from the jet’s sonic boom slowed interest and ticket sales. On Nov. 26, 2003, the Concorde – and commercial supersonic travel – retired from service.
Since then, a number of groups have been working on designs for the next generation of supersonic jets. Now an MIT researcher has come up with a concept that may solve many of the problems that grounded the Concorde. Qiqi Wang, an assistant professor of aeronautics and astronautics, says the solution, in principle, is simple: Instead of flying with one wing to a side, why not two?
Wang and his colleagues Rui Hu, a postdoc in the Department of Aeronautics and Astronautics, and Antony Jameson, a professor of engineering at Stanford University, have shown through a computer model that a modified biplane can, in fact, produce significantly less drag than a conventional single-wing aircraft at supersonic cruise speeds. The group will publish their results in the Journal of Aircraft.
This decreased drag, according to Wang, means the plane would require less fuel to fly. It also means the plane would produce less of a sonic boom.
“The sonic boom is really the shock waves created by the supersonic airplanes, propagated to the ground,” Wang says. “It’s like hearing gunfire. It’s so annoying that supersonic jets were not allowed to fly over land.”
Double the wings, double the fun
With Wang’s design, a jet with two wings – one positioned above the other – would cancel out the shock waves produced from either wing alone. Wang credits German engineer Adolf Busemann for the original concept. In the 1950s, Busemann came up with a biplane design that essentially eliminates shock waves at supersonic speeds.
Normally, as a conventional jet nears the speed of sound, air starts to compress at the front and back of the jet. As the plane reaches and surpasses the speed of sound, or Mach 1, the sudden increase in air pressure creates two huge shock waves that radiate out at both ends of the plane, producing a sonic boom.
Through calculations, Busemann found that a biplane design could essentially do away with shock waves. Each wing of the design, when seen from the side, is shaped like a flattened triangle, with the top and bottom wings pointing toward each other. The configuration, according to his calculations, cancels out shock waves produced by each wing alone.
However, the design lacks lift: The two wings create a very narrow channel through which only a limited amount of air can flow. When transitioning to supersonic speeds, the channel, Wang says, could essentially “choke,” creating incredible drag. While the design could work beautifully at supersonic speeds, it can’t overcome the drag to reach those speeds.
Giving lift to a grounded theory
To address the drag issue, Wang, Hu, and Jameson designed a computer model to simulate the performance of Busemann’s biplane at various speeds. At a given speed, the model determined the optimal wing shape to minimize drag. The researchers then aggregated the results from a dozen different speeds and 700 wing configurations to come up with an optimal shape for each wing.
They found that smoothing out the inner surface of each wing slightly created a wider channel through which air could flow. The researchers also found that by bumping out the top edge of the higher wing, and the bottom edge of the lower wing, the conceptual plane was able to fly at supersonic speeds, with half the drag of conventional supersonic jets such as the Concorde. Wang says this kind of performance could potentially cut the amount of fuel required to fly the plane by more than half.
“If you think about it, when you take off, not only do you have to carry the passengers, but also the fuel, and if you can reduce the fuel burn, you can reduce how much fuel you need to carry, which in turn reduces the size of the structure you need to carry the fuel,” Wang says. “It’s kind of a chain reaction.”
The team’s next step is to design a three-dimensional model to account for other factors affecting flight. While the MIT researchers are looking for a single optimal design for supersonic flight, Wang points out that a group in Japan has made progress in designing a Busemann-like biplane with moving parts: The wings would essentially change shape in mid-flight to attain supersonic speeds.
“Now people are having more ideas on how to improve [Busemann’s] design,” Wang says. “This may lead to a dramatic improvement, and there may be a boom in the field in the coming years.”
“There are many challenges in designing realistic supersonic aircraft, such as high drag, efficient engines and low sonic-boom signature,” says Karthik Duraisamy, assistant professor of aeronautics and astronautics at Stanford University, who was not involved in the research. “Dr. Wang’s paper presents an important first step towards reducing drag, and there is also potential to address structural issues.”
Published March 2012
  #473
Old 04-03-2012, 04:13 PM
Doug Lord's Avatar
Flight Ready
Rep: 919 Posts: 5,597
Thanks, Brian-most interesting!
yes, it is a revolution
  #474
Old 04-04-2012, 05:04 AM
yipster's Avatar
yipster yipster is offline
Rep: 1083 Posts: 3,337
Read that at gizmag and also had thoughts for bi-sails, caravan effect between cat hulls saved some pics thinking I better be a supersonic expert
Sail Loading on Rig, Rig Loading on Vessel brian eiland Sailboats 93 02-23-2011 07:19 PM
Sail Design? davef Software 18 02-14-2009 10:40 AM
The Concept Catamaran Project Duane Mc Boat Design 63 08-14-2005 07:34 PM
Why sail over power? Why power over sail? mackid068 Boat Design 19 04-12-2005 07:54 AM
geometry of sailing Sailboats 8 10-12-2002 10:58 AM
