Go Back   Boat Design Forums > Design > Hydrodynamics and Aerodynamics
  #376
Old 10-20-2008, 09:28 AM
schakel's Avatar
schakel schakel is offline
environmental project Msc
Rep: 38 Posts: 87
Outrigger
Originally Posted by yipster View Post
i too am wondering about these flows, as a rig heels how much loss it makes, mast rake, and what if when battens or a top boom would twist more windward
If you use an outrigger for a stay running from the top of the mast to the boom at the side of the ship you have what you want because it will bent the mast windward and you make the upwash effect even worse because you bend it even more towards the sky and therefore create more downward momentum in the mast. On th other hand it is just a small part of the upwash since most wind leaves at the backend of the sail.
I heard these outrigger boom were forbiden in open 60.
People are how you treat them and thats only half true.
  #377
Old 10-20-2008, 10:13 AM
Paul Scott Paul Scott is offline
Rep: 84 Posts: 272
Schakel- I was trying to remember a piece by Bogotaj on sails where he points out that sweep and taper effect the amount of twist needed for a sail. Which seems to imply that more powered up twist (not luffing) equals more forward power, as the top of the sail is pointed more downwind than the bottom. Can you quantify how much power loss upwash causes?
Yipster, FWIW, Stradivarious, the new AC Tri, cants it's mast all over the place. If you haven't seen it yet, get on Youtube and search BMW Oracle Castleswreath. My wife and I video'd this, and it seemed to me that in addition to using cant to steer, they seemed to be playing with flow direction.
Some have speculated that mast rake is part of what makes windsurfers go so fast. A lot of classes allow a lot of rake- Contender comes to mind. I think I saw somewhere that the more rake made the boat faster.
Anyway, rake plus taper seems to equal more twist. And according to Bogotaj, fractional rigs too.
Paul
EDIT- I found the Bogotaj piece- 'How do sails work?' article by Paul Bogotaj. My printout does not have the web address on it. I hope it can be found via Google.
  #378
Old 10-20-2008, 11:47 AM
schakel's Avatar
Rep: 38 Posts: 87
Quantification of loss
Paul
Loss of the main sail when under heel, but this is just high school physics, is the loss of wind compared to what you have with no heel. So the loss = cos*(angle of heel). in percentages of forwarding power.
Loss by the angle of twist is university physics and it takes me al night to figure that one out. If I do you be overwhelmed by the differential equations and Integrals and I do think you are waiting for that.
Main effect is what aeronautical engineers call down-wash which means the mass of air that is displaced by which angle per second.
Do you have Aero hydrodynamics of sailing, by C.A. Marchai in your library. I have so I know where to find it. (The academic answer)
But I do not have it here. If you are really interested I'll give you his equations as well.
  #379
Old 10-20-2008, 11:57 AM
Paul B Paul B is offline
Rep: 15 Posts: 1,770
Bogotaj works for North Sails and his article is on their website:
http://www.northsailsod.com/articles/article6-1.html
  #380
Old 10-21-2008, 04:31 AM
schakel's Avatar
Rep: 38 Posts: 87
Fractional rigs
I never knew why fractional rigs were used on my boats (a schakel and a dragon) Neither why the three top races have fractional rigs. (VOR, AC and Vendee Globe) I found it in the article from Paul Bogotai.
Thanks
  #381
Old 10-21-2008, 09:45 AM
Rep: 84 Posts: 272
Thanks
Also why my ULDB Cruising sled (designed 1998) has a 3/4 rig.
I'm wondering how the Musto rig compares to an A Class(ish) rig, given the taper and rake of the Musto, vs much less taper and very little rake for the cat. IC typical sloop rig too.
Paul
  #382
Old 10-21-2008, 10:27 AM
schakel's Avatar
Rep: 38 Posts: 87
Hoyt boom for genua
I ask this before but nobody could answer.
Since you know something about it: How come the Hoyt boom was never used on fractional rigs. And then I mean a genua that goes halfway the jib of the main.
What is the big benefit. the torque of the genua is controlled in a way that easily follows or prepares the main for optimal half wind forwarding power.
Here is an nice picture of what I had in mind. But with an genua instead and a Hoyt boom that you can apply on long half wind legs.
The yard is K&M who are terrific. Designer is van der Stadt.
but Hoeke (Pilgim Project by Wally)
and Gerard Dijkstra (Maltese Falcon by Perinni Navi)
are also house designer.
http://www.kmy.nl/
  #383
Old 10-22-2008, 06:55 AM
schakel's Avatar
Rep: 38 Posts: 87
I found it.
[quote=schakel;233700]
Loss by the angle of twist is university physics and it takes me all night to figure that one out. If I do you be overwhelmed by the differential equations and Integrals and I do think you are waiting for that
Page 306 and 307 of Marchaj gives an impression of how the angle of up wash is related to the lift and drag ratio. The power loss of the up wash is related to the forwarding power (in aerodynamics these are similar to what they call Lift in wings) so The L/D ratio in the graphs give the overall gain. If L/D is greater than 1 the overall effect is positive.
In figure 2.61 page 306 the optimum of the sail is somewhere around 7 degrees to the apparent wind.
But in Fig 2.62 the influence of the cambered sail is shown as well as the influence of the velocity of the wind.
Even more interesting is the stunning effect of a wing sail which provides almost 2 times the forwarding power. I have a concept for a wing sail on the drawing board but it is confidential.
  #384
Old 10-22-2008, 10:12 AM
yipster's Avatar
yipster yipster is offline
Rep: 1083 Posts: 3,337
"Loss of the main sail when under heel, but this is just high school physics, is the loss of wind compared to what you have with no heel. So the loss = cos*(angle of heel). in percentages of forwarding power."
trying to get that in the calculator but playing with a degree arc i see 5% surface loss at 20 deg heel, 25% surface loss at 45deg heel and about 75% loss at 75 deg heel, is that basicly the same idea?
i like to have some idea but these calcs must be rough figers as sailcup, 3d wash or a winglet play a role as well
  #385
Old 10-24-2008, 10:45 AM
schakel's Avatar
Rep: 38 Posts: 87
the cos function in your calculator
The cos function in your calculator is perfectly right. What I always have on my mind is the graph.
http://www.ies.co.jp/math/java/trig/...graphCosX.html
  #386
Old 11-14-2008, 07:34 AM
Mikko Brummer Mikko Brummer is offline
Rep: 124 Posts: 110
More sail aerodynamics
For those interested, we've posted a new article about sail aerodynamics at http://www.wb-sails.fi/news/Ad_aerodynamics
Mikko Brummer
WB-Sails www.wb-sails.fi
  #387
Old 11-14-2008, 09:47 AM
tspeer tspeer is offline
Rep: 1395 Posts: 1,537
Fantastic article, Mikko!
I especially liked the jet that impacts the lee side of the spinnaker - I'd not expected that.
Tom Speer
  #388
Old 03-01-2009, 07:20 AM
yipster's Avatar
http://en.wikipedia.org/wiki/Crab_claw_sail
re-reading Marchaj sail performance i'm impressed again with the crab claw
properly set it easy outperformes a bermuda or whatever other rig for that matter
the crab claw was only briefly discussed in this thread i see so i bring it up again
sail aerodynamics-perform1.jpg  sail aerodynamics-perform2.jpg  sail aerodynamics-perform3.jpg
  #389
Old 03-01-2009, 01:48 PM
Rep: 84 Posts: 272
And later, Marchaj displays the amazing superiority of a high AR Gunter, which has left me totally obsessed......
Paul
  #390
Old 03-01-2009, 10:47 PM
brian eiland's Avatar
Rep: 1577 Posts: 2,737
New Article by WB-Sails
Hello Mikko,
You might go back and edit your posted reference to the website. I believe it should be
http://www.wb-sails.fi/news/Ad_aerodynamics/index.htm
Sail Loading on Rig, Rig Loading on Vessel brian eiland Sailboats 93 02-23-2011 07:19 PM
Sail Design? davef Software 18 02-14-2009 10:40 AM
The Concept Catamaran Project Duane Mc Boat Design 63 08-14-2005 07:34 PM
Why sail over power? Why power over sail? mackid068 Boat Design 19 04-12-2005 07:54 AM
geometry of sailing Sailboats 8 10-12-2002 10:58 AM
