#286
| CT ... you have it right ... It is the L/D of the complete vessel that maters. The L/D of the rig is only one part of it. The L/D of the hull/foils in the water cannot be ignored. Above the water, only the sails produce lift, everything else is drag. Putting the very best, highest L/D rig on a barge is not going to make it sail very well. ![]() Have the fast windsurf guys started to experiment with drag reduction of the sailor? High L/D rigs with low CE are nice, then Bubba stands next to it in a baggy outfit and a PFD. How much "free" performance is to be had by experimenting with sailing suits and postures that reduce drag? The mast has to be a very small part of it. It cracks me up to see $$$$ in new sails on a boat that has had NO attention paid to the hull and keel.
__________________ Proud supporter of The Far Kurnell Cat Racing Team I have not failed. I've just found 10,000 ways that won't work. - Thomas A. Edison |
#287
Bob
__________________ ...I never learned a thing from an argument I won... |
#288
The velocity^3 dependence also shows up when total drag is computed by summing the dissipated power over all the wetted area elements dA of the wing or sail system and its wake: V_inf * D_profile = Sum [ rho V^3 Cdiss ] dA Where Cdiss is the dissipation coefficient and V is the speed over the area element dA. Note the V^3 factor, and the absence of pressure forces which don't explicitly contribute to viscous power dissipation. Cdiss is similar to the more familiar skin-friction coefficient Cf, except that it's much less weakly dependent on pressure gradients than Cf. In particular, Cdiss is strictly positive, even in separated reverse flow, so unlike Cf it also accounts for pressure drag due to separation. |
#289
| I think an important point that's often lost is one of the functions of the jib is to reduce the drag of the mast. In the absence of the jib, there would be a much larger separation bubble behind the mast, or just outright separated flow all the way to the leech. The favorable pressure gradient in the slot leads to quicker reattachment of the separation behind the mast and a significant reduction in the drag. I don't believe you can sum the drag of the mast alone with the skin friction of the sails and get a very accurate estimate of the profile drag of the whole configuration.
#290
#291
I'm not sure this is english. Paul Don't panic. |
#292
| Mast-Aft Development & Justification This is indead a great thread. I see there is renewed technical discussion of the headsail/mainsail 'slot' interaction , and some new participants with respectable technical backgrounds. Over the past number of years I have attempted to make a positive case for my mast-aft sailing rig configuration, both within, and aside of the technical discussions of these sail aerodynamics. I’m going to refrain from re-entering these technical discussions at this moment, and watch where they go. Rather I will choose to do a brief review of why I pursued my alternative rig configuration based upon the real-time observable phenomena that we experience as sailors. Because my submission is more ‘rig specific’ and not of the technical ‘sail aerodynamics’, I will make it here under the aftmast subject thread http://www.boatdesign.net/forums/sho...5&postcount=98 I also thought I would add in some other materials I've collected in the past. |
#293
| This is a great thread - many thanks to all the knowledgable contributors. I have a challenge for anyone willing to take it up - design a NS14 rig. NS14s are very simple boats but with very free rules on the rig design. Essentially, sail area is limited to 9.3sq m (100sq ft), which can be split in any configuration provided there is only one mast and it has a maximum length of 5.5m (18ft). So you can mainsail only, jib only, 6.9/2.4 main/jib split etc, etc. The mast section must pass through a 100mm ring and over-rotating wing masts are the norm. Hull length is 4.3m (14ft), waterline beam is 1.2m (4ft) and max beam is 1.83m (6ft). I'd be fascinated to see what you come up with. For info, these are typical: |
#294
The mainsail behind the mast cuts down the drag remarkably, compared to a bare mast. The Star mast is really slim and refined, though. |
#295
| What kind of calculation are the Star results from, Mikko? A Navier Stokes code?
#296
| Milgram did some stuff on mast sail interactions in the '70s. He made a statement like "significant amounts of lift are developed by the mast, which is probably why big old fat IOR masts are never quite as bad as we expect them to be" I can't remember whether it was tunnel or beginning of CFD applications to sails stuff. Best wishes Michael Storer
__________________ my boat pages |
#297
Dead downwind in a slow boat I am trying to get drag to the max. I'll get my crew to wear their pants on their head if it will help. I have had a bit of a browse through the past few pages and it seems to be focussed on solutions to the upwind problem. For fast boats this may be acceptable approach, but the results will be less useful for slower ones. So doesn't the problem become a whole set of optimum L/Ds for different headings? Or isn't that different apparent wind angles? ?? Best wishes Michael Storer
#298
At least according to this analysis, it would appear the mast in front of the mainsail is doing a good job in capturing some of the "suction force" at the leading edge of the sail, a problem well known for thin, plate-like airfoils. The viscous 3D-analysis reveals many things that won't show in an inviscid (panel method) analysis, or even a 2D N-S run. Separation bubbles (that play such an important role in sail aerodynamics) appear rather as "separation vortices" than "bubbles"... Heel angle, and the hull under the jib have a major effect on separation at the tack on the leeward side at larger angles. Also, wind gradient and the associated twist in the apparent wind (inflow) have a significant effect on the absolute forces produced by sails... it is understandable, when you think that you loose both wind speed & angle of attack in the foot part of the sails, where the most of the (triangular sails) sail area lies. In this particular Star case, for an AWS= 6 m/s and AWA= 27 deg, you only have 4,9 m/s and 23,5 degt at 1 m above sea level. If you refer drive and heel coefficients to the apparent wind at 10 m height (as you want them for a VPP, for instance), they tend to be much smaller (some 25% if I recall) than for a uniform flow.
__________________ Mikko Brummer WB-Sails www.wb-sails.fi |
#299
| How Airplanes Fly: A Physical Description of Lift Quote:
I was going back thru a quick review of some of this subject, and ran across this excellent reference site submitted by Tom Speer on another forum. So I felt obligated to bring the references up to date: ...per Tom This is an excellent article - one of the best you'll find. How Airplanes Fly: A Physical Description of Lift http://www.allstar.fiu.edu/aero/airflylvl3.htm |
#300
| Brian, it appears the link isn't working..... |
| Sail Loading on Rig, Rig Loading on Vessel | brian eiland | Sailboats | 93 | 02-23-2011 08:19 PM |
| Sail Design? | davef | Software | 18 | 02-14-2009 11:40 AM |
| The Concept Catamaran Project | Duane Mc | Boat Design | 63 | 08-14-2005 08:34 PM |
| Why sail over power? Why power over sail? | mackid068 | Boat Design | 19 | 04-12-2005 08:54 AM |
| geometry of sailing | Sailboats | 8 | 10-12-2002 11:58 AM | |
