Go Back   Boat Design Forums > Design > Hydrodynamics and Aerodynamics
Old 05-04-2012, 04:42 PM
naupigos_gr's Avatar
naupigos_gr naupigos_gr is offline
Rep: 11 Posts: 37
resistance of a vessel
Generally speaking lets say a pnmx with bulbous bow does it have less resistance than the same pnmx without bulbous bow design. As a result needs less effective power to move a the same service speed?
thanks and best regards
John
Give me a place to stand, and I will move the Earth
Old 05-04-2012, 09:15 PM
Rep: 1909 Posts: 1,755
Bulbs are very sensitive to speed and displacement, so at ONE speed above a Fn UNIQUE to the hull form, and ONE draft for the hull form, yes, a bulb would need less effective Hp to move at THAT speed. This is why route ships and things like cruise liners use them and other ships do not. See the following threads.
Bulbous Bow Design
Bulb Quest Again...
Forward Torpedo Tube on Ships
Old 05-05-2012, 08:21 AM
Rep: 11 Posts: 37
Hi jehardiman,
thanks for your reply.
you know I'm just evaluating some results from hullform and I got confused !
What vessel is this gor_ran Sailboats 0 01-06-2012 05:04 PM
Resistance chinnanva2003 Boat Design 19 10-15-2009 01:29 AM
vessel delivery fishingaz Open Discussion: All Things Boats & Boating 6 09-21-2008 01:38 PM
Resistance Bertil Boat Design 3 12-14-2007 12:18 PM
want a new vessel? THERIAULTMARINE Press Releases 0 08-28-2004 01:55 AM
