#136
1. Agree, but this effect exists. If model is running with wet transom and full-scale boat is dry transom, there should be some difference. If the flow from propeller effects flow separation at transom, there should be some difference also. 2. 62 series models were 8' long. Do You agree that without turbulence stimulators such tests at FnL=0.3 and lower can not be considered accurate enough? |
#137
The methodology and the accuracy of the measuring instruments being used play a significant part in any “experiment”. One can only answer the question of low Fn experiments by knowing what they measured how they measured it and with what devices and how accurate these devices were; are they calibrated correctly and frequently?. Theories are based upon real world observation. But the observation requires measurements...and measurements that are qualitative. The more accurate the device the better the quality data, which leads to better theories. As Leo has noted before, quiet rightly, the procedures/equipment that some ITTC test tanks use in their experimentation are somewhat lacking. Hence providing spurious results and leads to further confusion and hence lack of confidence. |
#138
| semi displacement hull at displacement speeds? is this plausible for all weather conditions? 27.3' uniflite is the boat me and my dad are wondering what to re-power it with? |
#139
| It's all in the vibe, I think ? ![]() |
#140
http://www.hoekdesign.com/ http://www.judel-vrolijk.com/ http://www.finot-conq.com/ http://www.germanfrers.com/ http://www.farrdesign.com/ http://www.juanyachtdesign.com/ http://www.mills-design.com/ http://www.kerdesign.com/index.html http://www.botincarkeek.com/ http://www.simonis.com/ http://www.reichel-pugh.com/index.html http://www.humphreysdesign.com/ http://www.felciyachts.com/ita/ http://www.blankyachtdesign.de/ http://web.me.com/jcboats/CorbyYachts/HOME.html http://www.seaway.si/ I don't know how many sailboats they designed 2010. Then there are many local small offices many of which do not even have web sites. Here is one from Finland: http://personal.inet.fi/yritys/strahlmann/index.htm He designed at least three production sailboats for 2010 (one designer office). Also there are several people designing purely sailboats for just one brand/company, like Jeppesen, but these you don't likely count, since they are not design offices. |
#141
- Judel/Vrolijk design powerboats one of those is very nice Grand Azur 33... - Mills was asking on this forum questions on powerboat design... - Humphreys has designed motoryachts one of famous is Ermis... - Etc. etc. etc. Dig a bit deeper and You will find a lot of interesting facts ![]() Besides many of designers also provide brokerage services, so they do not make living on design only... ![]() |
#142
| I didn't say these would be exclusively designing sailboats. Are you saying they are designing mainly powerboats like your office? |
#143
| : Originally Posted by Perm Stress View Post Sorry for being so stubborn, but my question was "why I could not use data, as published by the author?". If author find it possible to publish data starting from Fn=0.25, it is hard for me to see the reason not to use it. The question is where the data is published and why they are not included in technical paper? Agree that PBM is not scientific publication. I will ask Donald about this data, really interesting. It would be interesting to see the answer here.
__________________ All the stresses in my designs are 95% of permissible. |
#144
#145
#146
But, even if stimulators were used, I would still be suspicious of the data. And moreso if the ITTC line was then used to extrapolate to full-size. Leo. |
#147
2. Because it would be unprofessional to misuse the data that way. 3. Because one should not have blind faith in results, even if they are published in a reputable journal. Just a few reasons off the top of my head ![]() Leo. |
#148
#149
A logical question then follows: ...and now what? |
#150
| Efficient, economical low-speed hull? | DianneB | Boat Design | 8 | 08-22-2010 09:47 PM |
| Resistance Testing-Planing Hull Sailboat | Doug Lord | Boat Design | 9 | 05-06-2010 09:50 AM |
| Power/Resistance Calculation for Planing V-Hull & Fuel/Engine Required | Kapitan_Raider | Outboards | 24 | 11-26-2008 05:34 AM |
| Low planing speed | Steboe | Boat Design | 9 | 10-28-2008 09:07 PM |
| Low power tunnel, low speed drive | robrohdeszudy | Propulsion | 9 | 12-23-2004 05:09 PM |
