Old 04-19-2017, 04:08 AM
tkdchris's Avatar
tkdchris tkdchris is offline
Engineer
Rep: 14 Posts: 9
Planing Hull Transom Breakaway Angle
I'm looking at the mounting height for an outboard that is set back from the transom on a box, the cavitation plate needs to be just below the surface of the water as it would be if the outboard was mounted on the transom. Is there a formula for working out the the height adjustment required.
The theory as I see it is that when the craft is planing the water breaks away from the transom cleanly, which is lower than the dynamic waterline. This lower water will then of course raise up the further aft from the boat you go.
This will be a function of speed, deadrise and distance aft of the transom. Potentially running draft could also play a part.
Any help would be greatly appreciated.
Old 04-19-2017, 05:39 AM
Mr Efficiency Mr Efficiency is offline
Rep: 687 Posts: 5,428
A rough rule of thumb would be at least an inch per foot of setback. But really you need to have the ability to go up or down a hole or two after on-water testing, to fine-tune matters. And make sure the boat can handle the centre of gravity going rearward.
Old 04-19-2017, 10:12 AM
cmckesson cmckesson is offline
Naval Architect
Rep: 55 Posts: 156
The ballistic analogy published by Taravella et al would work here.
This states that, right at the transom, the slope of the surface is:
dz/dx = root-g root-2 root-T20 / v
where:
root-g means the square root of the gravitational acceleration
root-2 means the square root of 2.
root T-20 means the square root of the draft of the transom
v means the speed of the boat.
The units must be consistent, e.g. m/s2, metres, metres/second
The formulation is only exact right at the transom. The slope diminishes (according to this model) as you move aft of the transom.
Old 04-19-2017, 12:07 PM
jarmo.hakkinen jarmo.hakkinen is offline
Rep: 25 Posts: 64
Savitsky, Morabito et al have been researching this, and their formulas are as attached. They used those to study stepped hull performance.
Old 04-19-2017, 06:41 PM
So the trim angle is of negligible importance ?
Old 04-19-2017, 09:40 PM
Naval Architect
Rep: 55 Posts: 156
Mr. Efficiency: In the ballistic analogy the trim has negligible effect because even with trim there is very little initial vertical velocity imparted to the water. In effect the water particles "fall upward" from at rest, driven by gravity (i.e. hydrostatic pressure.)
Old 04-20-2017, 03:54 AM
tkdchris's Avatar
Engineer
Rep: 14 Posts: 9
jarmo.hakkinen: thanks, that's exactly what I've been looking for. When you add in the extra distance the outboard will be lowered into the water due to the vessel trim angle by moving it aft it looks similar to Mr Efficiency's rule of thumb.
Transom Angle smjmitchell Powerboats 3 08-31-2015
05:30 PM
Transom angle and plywood rasorinc Wooden Boat Building and Restoration 6 10-29-2012
11:54 AM
Transom Angle? ddrdan Boat Design 24 09-20-2010
03:23 PM
angle of exit for planing dinghy sawmaster Sailboats 14 08-01-2010
01:06 PM
What is transom angle? chase687 Boat Design 4 06-29-2005
01:21 PM
Powered by: vBulletin Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Web Site Design and Content Copyright ©1999 - 2017 Boat Design Net
