oscillatory bailing
Discussion in 'Hydrodynamics and Aerodynamics' started by lucdekeyser, Jun 9, 2014.
  1. lucdekeyser
    Likes: 13, Points: 18, Legacy Rep: 51
    lucdekeyser Senior Member
  2. daiquiri
    Likes: 258, Points: 93, Legacy Rep: 3380
    Kids are sometimes really incredible! :)
    That technique works, imo for three reasons:
    1. the boat floats when filled with water
    2. the cross-section shape of the bilge looks like a circular arc to me, or is very similar to a circular arc - hence good for allowing an unobstructed and smooth motion of the water.
    3. the size and inertia of the boat are sufficiently small to allow the crew (just one small girl, in this case) to oscillate the hull at the resonant frequency of the bilge water, thus synchronizing the water motion on such way to let mass inertia do the work of pushing it out of the bilge.
    Hence, IMO, it can be applicable in those limited number of cases where similar conditions exist.
    Thanks for sharing this video, it was very instructional. :)
    Cheers
  3. Mikko Brummer
    Likes: 83, Points: 28, Legacy Rep: 258
    Mikko Brummer Senior Member
    Here's a good simulation challenge, free surface & sloshing! Some similarity with the 470 in the aquarium I just posted.
  4. JSL
    Likes: 64, Points: 28, Legacy Rep: 41
    JSL Senior Member
    Works on very small boats ( I have done it many times) & canoes but not for large boats since the free surface effect could capsize the boat.
  5. Doug Lord
    Likes: 349, Points: 93, Legacy Rep: 1362
    Doug Lord Flight Ready
  6. Mr Efficiency
    Mr Efficiency Senior Member
    Don't think it would be a safe place to be in something oscillating like that, you could become the baby that got thrown out with the bath-water.
  7. JSL
    JSL Senior Member
    Update: In scouts and sea cadets we were taught this system in the event of capsize. One person would be on each gun'l and while still in the water alternately pull/push down to get the boat rocking. The water would slosh out port/stbd. You might remove about 50% but by that time you could re-board (carefully) and finish off with a bailer.
    Boats need positive floatation, should have a bit of freeboard when swamped (about 10% of the beam), and not too much clutter.
  8. lucdekeyser
    How was this technique called?
  9. JSL
    JSL Senior Member
    I don't recall. "Rocking Bailing" perhaps
