Go Back   Boat Design Forums > Design > Hydrodynamics and Aerodynamics
Old 03-21-2012, 03:10 PM
Godofredo Godofredo is offline
Rep: 10 Posts: 4
Michlet, L/B B/T ratio limits
I am a newcomer to this forum, so if this post has been covered before, my excuses. But it is impossible to cover everything to find out.
Michlet is mainly thought for slender hulls, that is waht I have read about it. But I have not seen any practical information about the limits regarding L/B and B/T. I just discovered this wonderful effort, but I know that there are limits. I do not want to be calculating the resistance of a vessel that is out of limits of the theory and math of the software.
Does anyone has an idea?
Is there any rule of thumb to (always) keep in mind about the limits of Michlet?
Regards
Old 03-21-2012, 09:42 PM
Leo Lazauskas's Avatar
Leo Lazauskas Leo Lazauskas is offline
Rep: 1934 Posts: 1,850
Regards
The main restriction is that the longitudinal slope should be small.
I would not rely on estimates of Michlet for L/B < 7. You might be able to
use it for smaller values, but you will need to also use some form of
empirical correction. See for example the thesis by Simon Robards to see
how thin-ship theory compares with experiments for a very large variety
of hulls.
Robards, Simon William, "The hydrodynamics of high-speed transom-stern vessels"
http://unsworks.unsw.edu.au/vital/ac.../unsworks:3426
Appendix D contains the resistance graphs.
Thin-ship theory should be able to order hulls correctly in terms of
resistance for lower L/B. For example, if thin-ship theory says that hull A
has less resistance than hull B, then that will usually also be the same
for experimental results. The actual drag might be in error, but the order will
be correct. The same is also usually true for many CFD predictions.
Good luck!
Leo.
Old 03-22-2012, 04:38 AM
daiquiri's Avatar
Engineering and Design
Rep: 2981 Posts: 3,497
Originally Posted by Leo Lazauskas View Post
See for example the thesis by Simon Robards to see how thin-ship theory compares with experiments for a very large variety of hulls.
Thanks for the tip Leo.
Your link let me to an error page, but this one works: http://www.unsworks.unsw.edu.au/prim...=unsworks_3426
Cheers
Old 03-22-2012, 04:49 AM
Cheers
Thanks, Slavi. I guess they have shuffled stuff in their library again!
Even if you ignore the predictions used in the thesis, the experimental results
are quite valuable to have on hand.
Earth population 'exceeds limits' RHP Open Discussion: All Things Boats & Boating 45 04-15-2009 04:41 PM
Grain runout limits nero Materials 1 04-24-2005 01:30 PM
Sheathed strip - Limits? Mohan Pakkurti Wooden Boat Building and Restoration 1 01-24-2005 11:01 AM
IACC Rule DSP limits jboat Boat Design 0 12-28-2004 11:47 AM
Speed Limits Coming??? sharkeymarine Powerboats 12 03-06-2003 11:48 PM
