lift without downwash?
Discussion in 'Hydrodynamics and Aerodynamics' started by lunatic, Oct 4, 2012.
  1. markdrela
    Likes: 30, Points: 28, Legacy Rep: 324
    markdrela Senior Member
    You are showing the velocities close to the airfoil, and your "downwash" immediately behind the airfoil is not what people normally call downwash. In the usual aero terminology, downwash of a 3D wing usually refers to the velocity well behind the wing, where the wing airfoil's local flowfield no longer has an influence.
    The far-downstream downwash velocity is associated with the wing's trailing vorticity, and must be present if there is lift on a wing with finite span. The presence of trailing vorticity and downwash also implies that there is an induced drag on the wing.
    In the infinite-span limit, the velocities in your sketch will still be present. But the far-downstream downwash and the induced drag will both disappear.
    1 person likes this.
  2. quequen
    Likes: 15, Points: 28, Legacy Rep: 199
    quequen Senior Member
    I thought on it as the airfoil modifying the flowfield from slightly forward to far behind, and local flow (appointed by telltails) as just part of the same (upwash-downwash) phenomena. Maybe I'm wrong?
  3. tspeer
    Likes: 305, Points: 83, Legacy Rep: 1673
    tspeer Senior Member
    Only if you have infinite span and produce a finite amount of lift.
    Generating lift means you are changing the momentum of the air by changing the direction of its flow. That is "downwash". When you do that over a finite span, you will not only produce downwash, but you will also have trailing vortices in the wake at the edges of the deflected air.
  4. gonzo
    gonzo Senior Member
    Do you mean by downwash that there is downward flow of air at the foot of the sail?
  5. Leo Lazauskas
    Likes: 155, Points: 63, Legacy Rep: 2229
    Leo Lazauskas Senior Member
    That is too close to the sail for the usual definition of downwash because
    it is influenced by "local" effects. As Mark said, downwash is a term usually
    reserved for the flow further aft of the sail where local effects are negligible.
    If you look up "horseshoe vortices" you will see a "bound" segment, which is
    located on the sail, and two "trailing" vortices that start at the bound
    portion and trail far behind the sail or wing.
    The trailing vortices are responsible for "downwash" and induced drag.
    (That portion of the trailing vortices on the sail, while creating a downward
    flow, are not usually regarded as part of the "downwash".)
    For an infinitely long wing (or one contained between wide long sidewalls)
    there are no trailing vortices, hence no downwash, and hence no induced
    drag.
    That's about as simply as I can explain it.
    Manfred.pech likes this.
  6. philSweet
    Likes: 648, Points: 113, Legacy Rep: 1082
    philSweet Senior Member
    So I googled downwash and had a good laugh. I thought you aero guys had all this stuff canonized.
    I learned downwash depends on the problem at hand. It has different uses.
    The meaning I had in mind was a sort of integral of momentum change in the direction opposite lift taken as the difference of momentum of the fluid entering and exiting a control volume surrounding the foil. However, it seems the vector can also be referenced to a vehicle's centerline- dealer's choice.
    I learned it also refers to the difference in angle-of-attack between the real 3d world and the nominal 2d world in terms of a foil's performance. The loss of lift do to low aspect ratio can be explained by a downwash caused by a tip vortex that reduces the effective angle of attack of the airfoil, predominantly near the tip.
    So there are the large scale, at-a-distance effects, and there are the localized effects. But the general idea is a change in momentum of the fluid opposite to lift.
    Now we just need to figure out what it means regarding sailboats. We could choose it to be perpendicular to the sail's course and opposite lift, or we could put it in the plane of the surface. The difference is the heel angle. The surface boundary condition kinda throws a monkey wrench into the works.
  7. philSweet
    Leo, we cross posted.
    I don't quite get this part. Others have alluded to it as well. I would expect downwash based on force balance for any finite span, regardless of boundary conditions. I would also expect the value to be independent of control volume and equal to lift. Is downwash an angle, or momentum change?
  8. Leo Lazauskas
    There are no trailing vortices at the wingtips of a finite wing with infinitely large
    "endplates" or walls, and hence there is no induced drag.
  9. TeddyDiver
    Likes: 150, Points: 73, Legacy Rep: 1650
    TeddyDiver Gollywobbler
    Not so IMHO.. Thou downwash and trailing vortices are related downwash still excist with infinite span too, anyway in angles of attack when the foil produces lift.
    BR Teddy
  10. daiquiri
    Likes: 259, Points: 93, Legacy Rep: 3380
    The answer to the OP question is - yes, it is possible, if the sail has an infinite height (or span). :)
    "Downwash" is an aerodynamic term coming from the world of aeronautics, and is hence a matter of definition. The concept of downwash exists only for finite-span lifting bodies, and not in case of 2D airfoils like the ones shown in the pics by Quequen. For a finite horizontal wing, a downwash is defined as the net downwards-directed vertical component of the flow velocity, induced by the vorticity generated along the span of a wing when it produces a positive lift. Hence, the downwash doesn't exist for airfoils (which are 2D cross-sections of a wing), and it doesn't exist for wings which do not produce lift.
    An important but often misunderstood thing is that the vorticity is created along the whole span of the wing, and not only at the wing tips - though the vortex intensity is generally highest in proximity of wing tips and other span-wise discontinuities (flaps, slats, ailerons, fuselage etc.).
    These concepts remain valid for sails and keels too, but the reference frame has to be rotated by 90° on a plane laying perpendicular to the flow. So I'm leaving it to your ability of visualization.
    Cheers
  11. upchurchmr
    upchurchmr Senior Member
    Aero experts,
    My understanding of the definition of downwash says this picture is not correct, Please make it perfectly clear for me.
    The green arrows coming into the sail is the airflow a ways in front of the sail. The green arrows leaving the sail should not be parallel to those coming into the sail, but should be pointed more across the page. This indicates that the air has been turned "down". Which on an aircraft wing would be "downwash" relative to the way the airplane normally flies.
    Somebody who does this professionally please set me straight. Is downwash flow along the direction of the mast, or across the width of the sail?
    Thanks.
  12. gonzo
    gonzo Senior Member
    My understanding of the term downwash on mainsails is that the wind spilled off the foot. That is why they made booms with shelves and laced the foot to it.
  13. Leo Lazauskas
    If you think that is a useful definition of "downwash" then by all means use it,
    but it won't wash with some of us ;P
    Perhaps you could show us how your definition translates into mathematics. :)
  14. daiquiri
    I agree with Leo. You guys should find an agreement about what the downwash means in the sailing world. The only definition I know is the aeronautical one, given in my previous post.
    Once you have decided what is the meaning of the word "downwash" for you, we will be able to make a more meaningful technical discussion about it.
    Cheers
  15. PI Design
    Likes: 21, Points: 0, Legacy Rep: 328
    PI Design Senior Member
    1. JordanMay
    2. Jamie Kennedy 108
    3. dustman
    4. MalSmith
    5. ToMy
    6. Remmlinger
    7. Lynton Banks
    8. BMP
    9. Bishiba
    10. Tristan perry
