#31
| Eric, Would you have any more illustration of your test? This seems similar to what is done on "Maddness" and other proas where the mast is displaced to weather and the jib tack is on the centerline, giving the increased separation you are discussing (assuming I understand). I asked the same question (different thread) but got no responses previously. Do you think the jib should then be cut differently since the interaction with the main would be somewhat different? On biplane aircraft the conventional separation for best lift is to make the separation = the chord width. Do you think there is enough analogy to make this a goal? I have in the past thought about using a bow pole similar to modern day sailing catamarans to place the tack much farther out than just the width of the bow. Too much? It would be lots of complication to go that far. Marc Quote:
#32
In the end, we did not include this option in the final design for Project Amazon, the client's budget was only so big. But the sailplan and the sketch of the deck plan on the cover indicate what I was thinking at the time. This is 18 years ago, now, wow! As for how far to separate the sails and how the jib shouild be cut--all those details are up for grabs and require research and testing. I could not say where the best position is to place the jib tack, and I would welcome the input of sailmakers who know better than I how to build sails. Building and testing ideas like these require interested clients with large checkbooks to pay for the development. It is very difficult to do the work on one's own checkbook unless you have your own large discretionary funds available to do so. Eric
#33
| Eric, Thanks very much. The other way to test such an idea is on a small boat. Since that is all I will be playing with it might be a possibility. I have an old Tornado catamaran. Do you have a freestanding carbon mast design that would be adaptable? 30' plus or minus. I actually am thinking about making a tri from the boat. The current 32' aluminum mast is ~60# and bent. The 17' boat in the pdf you sent sparked the question. Actually I was thinking about a rotating mast braced at the heel/keel and at boom level. I don't really have enough information to give you to specify real design loads but most of your discussion is based on bigger yachts, so I thought I would ask. Marc |
#34
Eric
#35
| Thanks anyway. Marc |
#36
| Eric In my previous post I was wondering what happens to the sheeting angle when you drop the tack to leward? Was there much experimenting with that? Cheers
__________________ Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers..... |
#37
Eric
#38
| My assumption would be that the angles would want to be the same, that should cause you to move the sheet position outboard on a tack. If you actually set this up for swinging the jib each tack the jib tracks would be permanately moved outboard as much as the tack, for a starting point. Probably lots of experimenting after that. |
#39
| A lot of boats have the jib sheet turning block on the rail already, so you can't move it outboard, and that is why I suggested that your only course of trimming would be to move the turning block forward or aft. Yes, lots of experimenting after that. Eric
#40
#41
| First, you guys are educating me and I appreciate it...I actually think I have an idea what you are driving at. Does this sound about right? Standard sloop, with jib/forestay...but stay (tack) can be moved port/starboard. I know it seems too simple, but that about right, essentially. I just want to be sure I caught the drift here.
__________________ Leave a place better. Congress is the enemy! "All ya gotta know!" Dog. Winona. |
#42
#43
| Daiq etal, made my gray day here shine... I have a plan in the oven for a device to use on my new little bateau, to a point. Question would be would the output equal or exceed the input. (I like many sailors, do lots o input, and reap moderate output for the labors. Love it.
#44
If you don't move the lead outboard the same amount as the tack your drive vector from the sail will move to leeward at the same angle as the tack change. That will increase your leeway angle, and the drag of the hull and appendages. Of course this is assuming you do not want to rotate the hull to windward as Eric seems to think is a viable option. Either way you are going to increase the hydro drag and you don't want to do that. To give you an example, my own boat originally had a sliding tack. This was used because the mast was set up for non-overlapping headsails and the idea was to use genoas. Since the spreaders were too long to sheet around at the required 8 degrees or so, the tack was allowed to slide to leeward (on a T-track) and the genoa track was set up at the same 8 degrees or so from the new tack position. This generated a similar force vector and a slightly more open slot. The hull and keel and sailplan were still "parallel" to one another, so we were not adding additional hydro drag. The tack was centered when the sailplan was changed to eliminate the overlapping sails. Then you have the I14s with their gybing boards. These boats are set up to basically sail with the board lined up with the direction of travel of the board of a "normal" boat. The hull is then rotated TO LEEWARD to be lined up with the direction of travel (including leeway). This, in theory, reduces the hydro drag and makes the boat faster. However, this has an effect on the sailplan. The drive vector from the sailplan is now pointed more to leeward than a normal I14. So you need to normalize the sailplan to the board, not the hull. So the sails are sheeted wider. If you draw this up you will note that you have essentially dropped the tack to leeward when you rotated the hull to leeward. So by sheeting the sails wider you end up with a sailplan similar to the way my boat was originally set up. This is also similar to your assumption. Some people think the wider sheeting/open slot provides a more powerful sailplan. Others disagree and think it may hurt performance. |
#45
| there's power and there's fast Sheeting angles are getting smaller and smaller on Grand Prix boats that point higher and faster than the old days
| Jib Hanks | durwoodghib | Sailboats | 10 | 10-08-2010 12:55 AM |
| Jib only sail plan? | stonedpirate | Boat Design | 15 | 04-03-2010 08:53 PM |
| Self tacking jib | Paul Scott | Sailboats | 34 | 08-07-2008 06:11 AM |
| jib sheet winch | sigurd | Sailboats | 2 | 05-30-2007 05:07 PM |
| Jib + Wingsail combination | Paul Scott | Sailboats | 7 | 09-30-2006 11:54 AM |
