Go Back   Boat Design Forums > Design > Hydrodynamics and Aerodynamics
Old 10-06-2011, 01:08 PM
vignesh vignesh is offline
Rep: 3 Posts: 35
improving performance - reverse bulbous bow principle, amplify wave near stern
Is it possible to reverse my bulbous bow principle,ie, can i by any means amplify the wave near the stern [increasing the crest amplitude] thereby i can use the increase in pressure to assist the ships motion.
Old 10-06-2011, 03:59 PM
Petros Petros is offline
Rep: 889 Posts: 1,005
Do I understand your question correctly? You think putting a bulb at the rear to create a stern wave will improve performance?
It seems to me the bulb would create both more form drag and skin friction drag, and that energy to form that stern wave has to come from the engine of the ship. I do not see how you can come out ahead on that calculation.
Old 10-07-2011, 08:54 AM
cyclops2 cyclops2 is offline
Rep: 94 Posts: 234
Cheap actual test setup.
Build a 8' long scale HULL model of a freighter model. Ballast it to the scale water line. Put a small screw eye into the bow JUST above the water line. A canoe with a electric trolling motor is also needed.
Clamp a 1" x 1" stick across the bow of the canoe. Add 2 very low friction ball bearing pullies to the stick. Attach one end of about 20# test braided fish line to the screweye in the model. The other end goes to a sensitive scale that can read the drag of the freighter when it is NOT NEAR the canoe bow wave. NEVER NEVER allow the tow line to drag in the water while towing test are being done!!!!!!!!!!!!!!! A wet line will NOT EFFECT results. Keep the distance between the bow & stick about 2' to 3'.
Get the idea ?
Then add whatever SCALE changes to the freighter you want to.
Is it as good as a $ 1,000,000 test tank ?
Better. Because you can pick SCALE... WIND SPEED & DIRECTION for more scale data on drags created by scale sized waves. You pick the day when winds are making scale sized waves.
Yes, we can not use scale sized molecules of water. But neither does a expensive test tank either
Absolute accuracy? NO. But percent of gain or loss in efficiency WILL BE RECORDED. That will be enough reason to move up to larger ..radio controlled.. scale models for more accurate data.
S
Old 10-07-2011, 01:58 PM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
In a word: No
-Tom
Old 10-07-2011, 05:13 PM
Rep: 94 Posts: 234
Not sure?
Try it.
There are always oddities in every science. Who thought adding a bulbous nose would be a improvment.
Test your idea.
Old 10-11-2011, 02:12 AM
Rep: 3 Posts: 35
The fact is increase in pressure will definitly assist the motion.
Old 10-11-2011, 05:46 AM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
No, it cannot work in the way you have imagined it.
However, it could work in another sense - to use a stern bulb for the creation of a wave system which would then interact with the wave system of the main hull, in order to obtain a partial wave cancellation. A total wave drag could then be decreased, but the total frictional drag would certainly be increased. The success of the operation will depend on the net balance between the two opposite effects.
Cheers
Old 03-14-2012, 08:36 AM
Rep: 3 Posts: 35
i would like to summarize
Is there by any means i can increase the pressure distribution at the stern region and use that increase in pressure to assist the ship's motion thereby i reduce the power required to propel the ship.
to summarize ,does increase in pressure in the stern region helps me to reduce the resistance?
I guess stern wedge ,apart from trim optimisation ,can help ships forward motion ,by above principle .correct me if i m wrong.
Old 03-14-2012, 08:48 AM
J Feenstra J Feenstra is offline
Rep: 42 Posts: 42
you can increase pressure by using a propellor....
Old 03-14-2012, 08:55 AM
Rep: 3 Posts: 35
well ,i am talking about adding upto propeller thrust .
Infact,propeller action reduces the pressure in the stern side .
Old 03-14-2012, 02:18 PM
Tim B Tim B is offline
Rep: 794 Posts: 1,407
Moving water takes energy. Moving water upwards takes lots of energy. QED, increasing wave height requires [more] power.
And bulbous bows change the effective ship length, but they only work at a certain speed. At other speeds they will make things worse.
Tim B.
Old 03-14-2012, 03:50 PM
DCockey DCockey is offline
Engineer
Rep: 1162 Posts: 1,656
Consider the effect of an adverse pressure gradient (pressure increasing in the direction of flow) on flow attachment/separation. An adverse pressure gradient can lead to separation which reduces pressure in the separated region and increases drag. Reshaping a hull so that the pressure increase near the stern may result in separation and increased drag.
David Cockey
Old 03-15-2012, 12:00 AM
Leo Lazauskas's Avatar
Leo Lazauskas Leo Lazauskas is offline
Rep: 1816 Posts: 1,422
You could also look at boundary layer suction (or blowing) near the stern.
Whether the energy expended in removing the fluid, or accelerating it is worthwhile, is a difficult question.
Old 03-15-2012, 07:54 AM
Tackwise Tackwise is offline
Member
Rep: 59 Posts: 34
Yes an increase of pressure in the stern region can reduce the overall resistance of the ship.
Simply put: The pressure resistance of the ship is the resistance force the ship 'feels' from the pressure at the bow area minus the pressure force the ship ‘feels’ at the stern area.
Increasing the stern pressure can therefore reduce the pressure resistance. Note that only the pressure resistance is reduced, as other resistance and propulsion efficiency factors may have increased depending on the chosen method of pressure increase!
One possibility of pressure increase at the stern (depending vessel type/speed etc, etc) can be accomplished with a stern shape that brings the water flow to nearly a full stop. Turn side of such a shape is the possibility of separation of the flow, which will generally increase the resistance instead of reducing it.
Last edited by Tackwise : 03-15-2012 at 07:55 AM. Reason: I should have put 'can' instead of 'will'
Old 03-15-2012, 08:04 AM
Rep: 3 Posts: 35
Yes ,I was thinking about modification of stern lines ,yes i was aware of the seperation resistance and also flow to the propeller .I m doing a study in it .
Bulbous bow addition Frosty Fiberglass and Composite Boat Building 34 08-19-2011 01:05 AM
Bulbous Bow Cb nmfb105 Boat Design 2 09-16-2009 09:09 AM
I'm conviced an eskimo style upswept split bow acts like a bulbous bow, but Squidly-Diddly Boat Design 4 08-23-2009 06:08 PM
Bulbous bow Hotel Lima Boat Design 1 09-09-2007 05:23 PM
Prop change for improving hull performance Luchog Sterndrives 2 09-14-2006 01:24 PM
