Go Back   Boat Design Forums > Design > Hydrodynamics and Aerodynamics
Old 01-29-2012, 06:53 AM
jonmatti jonmatti is offline
Rep: 10 Posts: 2
Hull shape for a 5m aluminum fishingboat
I am new here, just found this forum and it seems like there are a lot of knowledge and experience of hull designs here.
I am planning on building a 5-5,5 m center console aluminum boat, but i do not have the knowledge needed for the hull shape.
As far as i know the angle is vital for the characteristics, steep v shape for speed and flatter shape for stability and fuel economy.
I was planning on a 75-90 hp outboard and a planing speed in 15-35 knots and still have stability when standing still. I want a safe boat for big lake fishing, waves 1-1,5 m.
I am looking for some advice for angles and the sideview of the keel and bottom.
I am designing the boat in a surface modeling software with single bent surfaces only.
I am thankful for all help i can get! Since I am Swedish i might not know all the English terms.
Old 01-29-2012, 07:23 AM
Mr Efficiency Mr Efficiency is offline
Rep: 246 Posts: 711
First thing that came to mind was a centre console in Sweden being a bit c-c-c-cold ! You might want to concentrate on the aspect of dryness, as in as little spray entering the boat as possible. I believe the best way to achieve that is having a well raked stem and forefoot, to throw spray off flatter to the water. Keeping the chine high toward the bow doesn't hurt either. That's where I'd be starting, being assailed by sheets of cold water in an open boat takes the fun right out of it.
Old 01-29-2012, 12:26 PM
Rep: 3125 Posts: 9,399
The obvious choice is to purchase a set of stock plans or a semi/full custom set. There's quite a bit of understanding involved in designing high speed power craft, so unless you're interested in a few years of hydrodynamic and engineering study, you're best advised to get a set of plans and stick to the hull form shapes provided.
PAR Plans
PARBlog
Old 01-29-2012, 12:47 PM
Rep: 670 Posts: 2,457
So many nice designs available for Plywood glass construction. If you want to go alloy you must first do a weight study to see if you can build light enough to use these well proven designs
Old 01-29-2012, 01:24 PM
Most stock plains can be converted to other building materials, so if you find a plywood or foam cored build, you can likely have these converted to one of the few different aluminum builds (yep, there's more then one). Considering the cost of a 5m build, the price of this conversion would amount to an insignificant portion, of the total project outlay.
PAR Plans
PARBlog
Old 01-29-2012, 02:38 PM
rasorinc rasorinc is offline
Rep: 687 Posts: 1,175
Glen-L offers quite a few aluminum boats from 16' to 24' just click on outboards or inboards and they list the materials out eith wood or alum. Inboard plans can be converted to outboard.
Old 01-29-2012, 09:53 PM
Rep: 246 Posts: 711
Brrrrr.....the Swedish centre console, I feel cold just thinking about it. Best plan might to have a walk-around small centre cabin, or surround the console with shelter on three sides, that way two people should be able to stay out of the spray and wind, but you still have 360 degree movement round the deck. Over here you get sunburn and wind-burn, over there frost bite and wind chill.
Old 01-30-2012, 12:33 AM
Rep: 246 Posts: 711
If the OP has expertise in aluminium fabrication and welding, all should be well if he gets some suitable plans. Otherwise, it is just too ambitious IMO.
Old 01-30-2012, 01:08 AM
You might look at the Workstar range of alloy , Tony Castro designed small craft.
http://www.working-boats.co.uk/aluminiumworkboats.html
Old 01-30-2012, 03:05 AM
Rep: 10 Posts: 2
Thanks for the fast replies and interesting links!
Yes a plan might be a good idea, as long as I can get the one suited best for my needs.
Do you guys know of any vocabulary (images and text) for English boat terms?
A bit hard to understand everything in a foreign language
BR
Jon
Old 01-30-2012, 03:09 AM
Rep: 246 Posts: 711
BR
Jon
Are you experienced in welding aluminium ?
Book Inquiry - catamaran hull shape/profiles/ratios & hull design sonodelirii Multihulls 6 05-13-2012 08:16 PM
Can You Help Me With The Shape Of My Hull rich99uk Powerboats 10 08-16-2007 04:10 AM
Best Shape Aluminum Stock for Hull Frame? RockReeve Metal Boat Building 8 02-18-2005 04:47 AM
Hull Shape mrbrown Boat Design 1 08-09-2004 11:24 AM
20-foot fiberglass fishingboat plans hungdynasty Boatbuilding 1 10-22-2003 08:16 PM
