Boat Design Forums (http://www.boatdesign.net/forums/)
-   Hydrodynamics and Aerodynamics (http://www.boatdesign.net/forums/hydrodynamics-aerodynamics/)
-   -   How to go about checking hydrodynamics for a catamaran boat? (http://www.boatdesign.net/forums/hydrodynamics-aerodynamics/how-go-about-checking-hydrodynamics-catamaran-boat-48982.html)
amispurs 11-23-2013 02:45 PM
Hello!
I'm desining a catamaran boat. The dimensions for each hull :
Length = 14 ft. Beam = 2.25 ft . Draft = 1.25 ft
The catamaran should have a payload capacity of 4 people.
Now that I've designed a single hull, do I check the hydrodynamics? Or should I build the entire catamaran (with central platform etc.) and then do so?
Also, how exactly do I use the hydrodynamics and resistance tools to make sure the design is okay?
I'm a beginner at boat design running a deadline for project submission. Please do help!
Amith
Mr Efficiency 11-23-2013 06:24 PM
What were the requirements outlined for this project ?
PAR 11-24-2013 01:09 AM
Lets have them play with it for a while, before we send them off to design ferries?
amispurs 11-24-2013 01:17 AM
The catamaran is going to be used as a USV for environmental research such as measuring pollution levels etc. We will be testin it in calm waters at first and then possibly deploying it in the sea.
I designed the cat based on an existing design I found online.
Powered by: vBulletin Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Web Site Design and Content Copyright ©1999 - 2017 Boat Design Net
