Go Back   Boat Design Forums > Design > Hydrodynamics and Aerodynamics
Old 01-01-2012, 01:14 AM
MechaNik MechaNik is offline
Rep: 46 Posts: 92
For A load sensor you should ask around the larger rigging and sail makers. This is where a friend of mine borrowed one from (quietly on the weekend), it was wireless and recorded constantly. He was trialing a "friction less spray coating" on his 12ft skiff so needed a fair size scale.
Old 01-01-2012, 07:47 AM
aka Terry Haines
Rep: 1814 Posts: 3,009
Originally Posted by Alik View Post
Yes, this works, we did and it works.
The question is how high should be towing point on kayak.
The lower the better presumably, too high would depress the bow and affect the test results. The towline needs to stay out of the water of course but this kind of test should be done in flat water to be valid.
You can test a kayak to see if it has a yawing tendency: just paddle fast in a straight line then stop paddling. If it is going to yaw it will veer off course after a few seconds instead of coasting in a straight line.
Dances with Turkeys
Old 01-01-2012, 07:50 AM
ldigas ldigas is offline
Rep: 43 Posts: 160
This is qualitative testing of 1:10 scale model of 16m catamaran:
http://www.youtube.com/watch?v=FvYlP...1&feature=plcp
Is that a life vest on top ?!
Old 01-01-2012, 08:28 AM
Alik's Avatar
Alik Alik is offline
Rep: 1070 Posts: 2,036
Yes, it works as emergency floatation
Old 01-01-2012, 09:24 PM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
This is basics: normally models are tested without appendages. Why? Because Reynolds number (Rn) on small scale appendages are low, so they can not be modelled that way. Usually appendages are tested separately at higher Rn or added as result of calculation.
For testing real size kayak it might work to test with skeg.
No mention was made of any model.
-Tom
Old 01-01-2012, 09:29 PM
Alik's Avatar
-Tom
But I was talking about possible problems of MODEL testing. Because we test models this way sometimes. Clear?
Old 01-03-2012, 11:03 AM
Mariner
Originally Posted by Expandacraft View Post
Hello members,
I'm new here and hope this is the right place to pose this question. I'm the designer and manufacturer of Expandacraft modular boats and wanted to know if there is an inexpensive way to determine drag coefficient. My bows are wave piercing and it is my theory that while they may not be as slick as some kayaks in flat water, they are in fact more efficient into the waves.
My goal is to actually measure and document the data, not simply to calculate a number. I'm thinking of some sort of devise which I can attach to a motor boat and test in (real world) situations.
Just not sure why you brought up MODELS when in the OP there is clearly no mention of them.
Oh, Happy New Year Alik
-Tom
Old 01-03-2012, 11:57 AM
Rep: 749 Posts: 1,314
While you are at it, you will surely want to test at different pitch angles. At least one bow down test and another bow up. Phil made reference to that situation above.
To complicate matters a bit, you need to consider aerodynamic drag as part of the total drag figure. The connecting structure on the cat planform will have some influence on your derived numbers. Towing upwind, downwind and crosswind will provide some clues, but only clues, about the aero factors. As you will be using various ballast items to simulate actual sailing or motoring displacement conditions, it needs to be as well hidden from the airstream as you can make it. Why is everything that has anything to do with boats so damned laden with variables?
Old 01-03-2012, 01:52 PM
tspeer tspeer is offline
Rep: 1395 Posts: 1,537
Take a look at Frank Bethwaite's "High Performance Sailing". He describes the tests they did with towing dinghy hulls to get the drag of one vs another. They towed two hulls from opposite ends of a pivoted cross beam to get a sensitive measure of the difference in drag between the hulls.
Tom Speer
  #25
Old 01-03-2012, 02:08 PM
aka Terry Haines
That is a simple and accurate way to determine if a design or other change is good or bad. Simplicity is important here. Expandercraft are clearly not aimed at performance-oriented markets, so there's no need for anything more complicated . . .
Dances with Turkeys
  #26
Old 01-08-2012, 02:16 PM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,400
Yes AK, this 'drag testing' might be over complicating the evaluation of little boats.
I would be tempted to start with a few people to just paddle comparative boats, and see if anyone can tell the difference ( maybe even have a few informal races), swapping between boats.
If you cant tell the difference - it doesn't matter. If people report discernible performance differences - that's all you need to know.
But, if you still need to 'quantify' the results, I think the only true test is to stick a battery powered trolling motor on two boats, and measure the current draw at the same boat speed in the same conditions. (with passengers, and swapping motors for averaging results of course.)
  #27
Old 01-08-2012, 03:20 PM
aka Terry Haines
Originally Posted by rwatson View Post
. . . I would be tempted to start with a few people to just paddle comparative boats, and see if anyone can tell the difference ( maybe even have a few informal races), swapping between boats . . .
It's surprising what can be learned from such a simple test as that. A buddy and I did swap tests between a rotomolded kayak whose manufacturers claimed a racing background and a lightweight home-built (and designed) plywood canoe. We were surprised to find that a cruising level of effort would put the 11.5' canoe ahead about a length per minute but in an all-out race the 13.5' kayak would take the lead. This happened every time, didn't matter who was in which boat, although we're a fair bit different in weight and height. Length and wetted area matter even between very different designs. You could hear the canoe during the speed tests but the kayak was still silent - we probably did not have the strength or skill to get the kayak up to the speed of which it is capable so it was wasted on us.
Since the ply canoe was intended for relaxed cruising, both boats clearly met their intended purpose, but now everyone wants the ply boat, which also revealed something about ourselves - we're lazy! So, since the ply canoe is half the weight of the plastic kayak, the rule now is, you carry the other guy's boat to the water . . .
Dances with Turkeys
  #28
Old 02-15-2012, 09:14 AM
JotM JotM is offline
Rep: 22 Posts: 54
Here's how drag coefficient testing is done to determine the handicap of open water rowing craft in NL.
The setup is drawn schematically in slide 7 of the presentation here:
http://www.federatiesloeproeien.nl/f...cap-pres-1.pdf
In order to determine the power exerted during a race the parameters A and B of a total drag coefficient-function is determined for the average rowing speed over the last season, which is considered to follow the function Cw=A/(1-(v/B)^2) -> power P = Cw*v^3 <=> P = A/(1-(v/B)^2)*v^3
The crew for which the average power / number of rowers is the highest, wins a race, where the average power is determined by multiplying the average speed over the entire race to the power of 3 with the drag coefficient for that speed and dividing by the time rowed.
(Pav,n=P = A/(1-(v_av/B)^2)*v_av^3/(()*n) - where Pav,n is the average power divided by n rowers, v_av is the average speed over the entire race and n is the number of rowers)
Regards,
Jaap
real world measured drag coefficient, heeled and straight, of a common glass keelboat peterchech Sailboats 16 12-11-2011 04:48 PM
Bubba Boat Test...test that boat before you buy brian eiland Open Discussion: All Things Boats & Boating 2 07-03-2011 12:21 PM
Prismatic Coefficient hwsiii Boat Design 62 09-27-2009 09:37 AM
Cheap to run, cheap to build electro plywood cruiser ? ASM Boat Design 72 08-08-2008 09:13 AM
Profile Drag Coefficient dtoshni Boat Design 4 06-19-2008 05:52 AM
