Go Back   Boat Design Forums > Design > Hydrodynamics and Aerodynamics
Old 10-19-2011, 07:56 PM
Petros Petros is offline
Rep: 889 Posts: 1,005
rather than putting a flap in the foil itself, why not use a separate smaller "trimming" foil near the trailing edge to alter the flow. It would be supported and hinged off of tabs or supports near the TE of the curved foil. Solves the problem of warping a curved foil.
Old 10-19-2011, 08:03 PM
Doug Lord's Avatar
Flight Ready
Rep: 919 Posts: 5,597
Thanks, Petros. Sounds like it might prevent the foil from being retracted ,if I understand you correctly.
yes, it is a revolution
Old 12-08-2011, 07:10 PM
Doug Lord's Avatar
Flight Ready
Flap on a curved foil
Just discovered this picture which appears to show a curved foil with a flap:
click on image-then click on it again--
Old 12-08-2011, 08:04 PM
Paul B Paul B is offline
Rep: 15 Posts: 1,770
Looks like something else to me.
Old 12-08-2011, 08:17 PM
Doug Lord's Avatar
Flight Ready
I believe you!
Old 12-09-2011, 04:43 PM
I believe you!
Maybe if you spent a few minutes thinking about the mechanics of this type of system you would not have thought you were seeing a flap.
Old 12-09-2011, 04:46 PM
Doug Lord's Avatar
Flight Ready
I see your point. You're 100% right-thanks!
Old 12-09-2011, 08:14 PM
A flap like that could work if it was made of rubber or vinyl or a similar flexible material. you would not get a lot of range of movement out it but it would work for trimming.
for that matter if you make a stiff rubber trailing edge you would not need a hinge either (with its draggy gap), you could just "warp" the TE to get it to trim. That would be a nice clean set-up.
Old 12-21-2011, 10:28 AM
sigurd sigurd is offline
Pompuous Pangolin
Rep: 43 Posts: 628
jet flap.
  #25
Old 12-21-2011, 05:13 PM
Manfred.pech Manfred.pech is offline
Rep: 48 Posts: 67
If you are able to lengthen/shorten the forward beam telescopic and keep the rear one adjustable with a hinge (or flexible at a small multi) you do not need a flap for a bent board.
  #26
Old 12-21-2011, 06:07 PM
Doug Lord's Avatar
Flight Ready
The idea,from my perspective, was to be able to connect the flap to a wand-based altitude control system and use in a similar way to a t-foil.
  #27
Old 12-23-2011, 11:42 PM
aka Terry Haines
Rep: 1814 Posts: 3,009
My thoughts:
An elastomeric flap may vibrate.
Are flaps required along the entire length of the foil or can a flap be used just on a straight portion?
If flaps must go on a curve, the simplest solution is several short flaps mounted on a single, flexible rod, with the ends of each flap beveled to prevent flap-to-flap interference.
As an alternative to a rotating flap pivoting from the trailing edge, have you considered a leading edge slotted flap with a linear movement? Viewed from astern as shown in your sketch attached to post # it would have the same curve and would move along the NW to SE diagonal, creating a variable slot along the entire length of the foil without need for flexible elements. The slot would not be the same along the entire length, this would need some thinking about from someone better informed on slot design than I am, ditto the control of lift.
Dances with Turkeys
  #28
Old 12-24-2011, 08:22 AM
Doug Lord's Avatar
Flight Ready
Originally Posted by ancient kayaker View Post
My thoughts:
Thanks, AK. In my application, approximately the lower third of the foil would use a flap. The slot might work but it would need the active participation of a Mark Drela or Tom Speer to consider the viability of that solution-I couldn't do it.
  #29
Old 12-24-2011, 11:41 AM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
How about making the entire foil semi rigid and inducing a curve or contour to it on demand?
Somewhere I read it can be quite effective but perhaps ahead of it's time.
It makes sense to me...
-Tom
  #30
Old 12-24-2011, 11:45 AM
Doug Lord's Avatar
Flight Ready
-Tom
Thanks, Tom-might work with some kind of shape/memory material, but its beyond me.....
Stern flaps and interceptors terhohalme Boat Design 32 03-17-2012 08:10 AM
Gurney flaps garydierking Hydrodynamics and Aerodynamics 11 06-30-2011 04:32 AM
Flaps in the planing hulls Cedro Boat Design 2 04-25-2009 03:03 AM
Flaps and formulas fede Boat Design 2 05-17-2005 12:52 PM
Foil design Dr X Sailboats 4 10-12-2004 06:44 AM
