Go Back   Boat Design Forums > Design > Software > General Computing
Old 12-22-2010, 06:14 AM
yipster's Avatar
yipster yipster is offline
Rep: 1083 Posts: 3,337
thanks for the reply's jeff and bert, my wired problem remains tho..
with the wifi stick in again and network cable out i auto-log-in, no problem
can type boatdesign as much as i like but cable ping say's no reply
had it once before around this summer but after a week holliday it cured itself
DNS cache may likely be the culprit as i uploaded my site again and links than might get lost
i'm having upc-chello as provider the biggest around in europe and would think they do okay, have a poor tv reception too tho
out for cristmas shopping now but check things again later, back to cable now and of my neighbours network
Old 12-22-2010, 03:10 PM
breschau breschau is offline
Rep: 10 Posts: 48
Mr. Yipster have you tried to use a different name server?
Old 12-23-2010, 01:20 AM
BertKu BertKu is offline
Rep: 130 Posts: 1,035
Hi Breschau, What I have concluded is that Yipster can via his neighbour WIFI systen log into the boat.net. Thus this is a different service provider. Also I concluded that there is nothing wrong with his computer. If he can log in via WIFI and his neighbour, but not via the cable system, his computer must be O.K.
Breschau, could you help me by writing to me excactly what you do and see, when you up-load a jpeg or any other file. This helps me to find the error I am having. i.e.
1) you click with the left button on the paperclip icon >>>> this is what happens, if you click with the right button, this is what happens etc. etc. This is what you see at the left bottom of the screen etc. etc.
I do know, that you run on linux, but it may just give me some idea's to solve my problem. Many thanks if you are willing to do so.
Bert
Old 12-23-2010, 01:34 AM
Jeff's Avatar
Jeff Jeff is offline
Moderator
Rep: 921 Posts: 1,371
Bert - you may have already said this, but did you test with a second web browser on that same computer already other than your primary web browser? For example if you use Internet Explorer, did you give Firefox a try?
Also are you able to < upload to the gallery > on this site?
If the issue were routing or firewall related on this side, it should be affecting everything and so I'm perplexed why the issue only affects attachments. I was able to upload an image logged into your account with the temporary password I reset on a windows 7 64-bit machine here without issue using IE8 and firefox; I can't spot anything amiss with your forum account itself but I wanted to be sure before wasting your time.
I've been in the habit of using zonealarm as a software firewall on windows boxes for a decade now to monitor any programs which try and make an outgoing connection, but I encountered an intermittent issue with zonealarm when I updated to a win7 64-bit box where it was intermittently causing one of the network links to choke and perform at very slow speed and outright lockups of the network. Are you using any third-party firewall or security/av suite applications?
When you left click on the attachment icon or left click on manage attachments button you should see a smaller new window appear like this: http://www.boatdesign.net/forums/faq...chment_explain
Your browser may prompt you to allow the manage attachments new window to launch - if so, choose to allow this "popup" from this site.
Then in the manage attachments window, left click Browse and then select the file from your computer, then left click the upload button.
It may take a minute to upload depending on the size of the file.
Then close that window and in the main window below in the "attach files" section you should see the filename of the file you just uploaded. At this point you can go ahead and "submit reply" with its attachments.
Old 12-24-2010, 08:41 AM
yipster's Avatar
really thought it was a dns cache problem but turned out a firewall hick-up, thx for fixing Jeff
now i can splash my nonsense here again
Old 12-24-2010, 09:00 AM
No, Jeff, because I was able to up-load onto your gallery site.
My apology, I gave you a private message instead of a reply on this thread yesterday, before I had to run.
I am still stuck on the paperclip, it does not allow me to open a window in the same manner as with uploading onto your gallery. I loaded, without any problem, the picture DSC0004. I concluded that I still have a setting maybe wrong, or that we still have a firewall problem somewhere, either at my service provider. However, it is Christmas time, I wish you a very Merry Christmas and maybe we should leave it till some times next year, and attend to this problem further. I am not in the hurry, but I should mention that suddenly I got pages and pages of your HTML source code in my box. I am not available for the next 48 hours. I wish everybody a marvelous Christmas.
Bert
upload video question longtailboats Forum Questions and Suggestions 3 12-13-2010 10:00 PM
Error message when trying to upload photos (resolved) gonzo Forum Questions and Suggestions 3 06-07-2010 04:23 PM
Please help, I have a problem.... JOHNSCOTT64 Open Discussion: All Things Boats & Boating 19 05-09-2009 12:25 AM
Gallery Upload Issue Sean Herron Forum Questions and Suggestions 4 11-01-2008 08:50 PM
TV problem yipster OnBoard Electronics & Controls 12 11-07-2007 09:32 AM
