| stations onto unrolled surfaces Rhino How to get stations onto surfaces, Tried putting on same layer as surface, but no joy, any answers please |
| if I understand your question right I would unroll the surface and select the station when prompted for selection set. john |
| Stu you have to select the contour/section lines that are on the surface plus the surface you want to unroll. |
| lazy jack what are you trying to do? i can probably walk you through the process if you define your objective john |
| Match surfaces in Rhino | toda | Software | 12 | 05-13-2007 09:20 PM |
| Drawing surfaces of the bulb in Rhino | toda | Software | 7 | 04-19-2007 07:18 AM |
| Exporting a solid in Autocad to Rhino as surfaces | SOYUTA | Software | 12 | 12-27-2006 03:09 AM |
| Stations in Multisurf: help!! | Akeswins | Software | 0 | 12-11-2005 12:34 PM |
| Use Rhino to create surface between stations? | ivansalasj | Software | 9 | 01-18-2005 05:08 AM |
