Go Back   Boat Design Forums > Design > Software > General Computing
Old 07-24-2011, 10:26 PM
DCockey DCockey is offline
Engineer
Rep: 1162 Posts: 1,656
PhotoModeler also has an optional version, PhotoModeler Scanner, which works in a more automated manner to create a surface mesh from a number of photos - IF the surface has a sufficiently random "texture". Stone appears to work well, particularly if weathered; smooth surfaces with a uniform color don't work at all. Also the requirements on the photos are more stringent than with PhotoModeler and Rhinophoto.
Old 07-24-2011, 11:09 PM
Willallison's Avatar
Rep: 2319 Posts: 3,502
That's the one... thanks DC...
As I said, I have no experience with it, so can't suggest as to its usefullness or otherwise...
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 07-25-2011, 12:27 PM
peter radclyffe's Avatar
peter radclyffe peter radclyffe is offline
Rep: 576 Posts: 1,066
you are all most helpful
one blade scanned on A4 size scanner Çemberci Open Discussion: All Things Boats & Boating 7 05-31-2007 07:02 AM
Scanner used to match gelcoat color jbrown15 Materials 0 04-13-2004 11:10 AM
