Go Back   Boat Design Forums > Design > Software > General Computing
Old 11-09-2007, 11:32 PM
Ausiwik Ausiwik is offline
Rep: 10 Posts: 24
problems with Rhino or computer in render
Hi All
I hope some one can throw light on this problem
I'm using Rhino 2 and my models are progressing, (getting better )
with more surfaces and so forth but now I'm not able to render properly in fact my computer seems to lock up. I can clear it most times by hitting escape but some times this has no effect
This has been a progressive problem. As Iv made models more complicated (for me ) the render has got slower till now it even misses surfaces out.
Iv checked CPU and it hits 100% usage and stays there when it stops
I have an AMD Athelon 3000+ 1 gig ram and a 256mb radon video card. Is this insufficient (not according to rhino blurb, even good enough for version 4)
I put in some more ram to make it 1.5 gig and it had no effect what so ever.
I'm ok with getting new parts if needed but would like to be sure I'm going to fix the problem first. The computer works beaut for everything else even does video editing quite well. I am using XP home
Thanks Ausiwik
Old 11-12-2007, 11:09 PM
Sean Herron's Avatar
Sean Herron Sean Herron is offline
Rep: 405 Posts: 1,532
Surfaces Or Mesh
Hello...
If surfaces - change u/v degree
If mesh - lower polygon count
SH.
Old 11-13-2007, 02:03 AM
Rep: 10 Posts: 24
Hi Sean
Thanks for getting back on this. Ill look at both things to night, however something tells me the file is corrupted or maybe the program is.
I sent the same drawing to a friend with rhino explaining the problem his computer locked up as well and the file is only 650kb he is easily able to handle way larger files with similar computer setup to mine.
I down load the trial version of rhino 4 and imported the base drawing I was having a problem with.
I was then easily able to complete it and render it with out a problem so looks like its some what isolated I do have a mixture of surfaces and mesh I think, seems I use whatever puts it together (I have a lot to learn )
Thanks anyhow the thing Ive been hung up on is a "Billabong hard dodger". Ill attach my blog its in hard dodgers (I can't seem to paste it here ) http://marshalldesign.blogspot.com
Thanks
Steve Marshall
Old 11-13-2007, 05:55 AM
duluthboats's Avatar
Senior Dreamer
Rep: 771 Posts: 1,578
The only thing that would lock up my old PC in Rhino 3 is reflective surfaces and more than one light source. Is your model sitting in water or do you have lots of shiny surfaces?
Gary
"The hand feeds the mind."
Weston Farmer
Old 11-13-2007, 06:15 AM
kerosene kerosene is offline
Rep: 157 Posts: 406
also check you mesh settings - hoe dense is the polygon mesh when rendering. with wrong setting you are creating tons (millions) of un-necessary polygons.
Your computer's specs are fine.
Old 11-13-2007, 02:15 PM
Rep: 10 Posts: 24
Hi Guys Ill look at those things now I do have shiny surfaces all over with out good reason plus Ill check mesh settings
Thanks
Steve M
Render in Rhino 3 catsketcher Software 2 05-16-2007 12:03 PM
3d render tz3dcom Services & Employment 0 05-16-2007 05:04 AM
One more interview: Victor Gonzalez, CEO of Next Limit (Maxwell Render) folini Software 0 04-13-2007 10:49 AM
Rhino render ARGO Software 2 05-16-2005 09:36 AM
Great RENDER!!!!! desi Software 1 12-28-2003 09:49 AM
