Go Back   Boat Design Forums > Design > Software > General Computing
Old 05-24-2010, 01:35 PM
peter radclyffe's Avatar
peter radclyffe peter radclyffe is offline
Rep: 576 Posts: 1,066
thanks Tad
Old 05-24-2010, 02:16 PM
perhaps my offsets are wrong, this is not the shape of turn of bilge
Old 05-24-2010, 02:29 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Rep: 2037 Posts: 1,719
Here's the lines drawing from that surface....
radclyffe28-lines.pdf
Old 05-24-2010, 03:23 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Not necessarily wrong, just that you provided no info below that -1 waterline. Thus as the drawing below shows....all guessing below that lower offset.
The red spline is about what you see above, the blue spline also goes through the same offset points....just has a completely different shape. This is the designers problem...how to transmit enough data to build the shape you intend....traditional offset tables work....another (lower) waterline would help
Old 05-24-2010, 03:29 PM
sorry Tad, i have the rabbet & sheer heights, i have to type them
Old 05-24-2010, 05:06 PM
Guest62110524 Guest62110524 is offline
Previous Member
Rep: 0 Posts: 0
Peter, sorry could not assist more
I dont know how to extract either so what I do is section the lines in rhino, at each frame station, draw the structure and just measure the frame at wl,s, buttocks, sheer, and or chines if any
Do you have R4?
best Stu
and if Tad OR ANYONE could show me how to call offsets from R4 ORMaxsurf, that,d be wonderful
Old 05-24-2010, 11:45 PM
i dont have r 4, i shall look at it, thanks Stu
Old 05-28-2010, 03:03 PM
hi Tad, did you get the heights
Old 05-28-2010, 03:37 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Peter,
I've been on the road for a few days, just back and catching up...I'll look at this again over the weekend.
  #25
Old 05-29-2010, 03:42 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Model revised with -2 waterline....
  #26
Old 05-30-2010, 05:09 AM
thanks Tad
  #27
Old 10-11-2010, 04:14 PM
[IMG][/IMG]
I need help with Table of offsets cbboatworks Wooden Boat Building and Restoration 0 09-05-2007 02:25 PM
Offsets in Freeship robmill54 Software 1 05-29-2006 10:38 PM
Offsets wrabbit Software 7 04-17-2006 05:53 AM
table of offsets aqua_ambulat Boat Design 2 09-17-2005 07:07 AM
Hull Offsets Alixander Beck Software 0 09-06-2005 02:52 PM
