| model scanner is there a scanner I can use to print the shape of half models, thank you |
| There are laser scanners.
__________________ Gonzo |
| thank you, we used one on eilean, but is there a cheap one |
| Unfortunately, not that I know of. However, with half models you can trace the lines. That is the reason to make half models. The layers are set over paper and then use a pencil. I can see that making a table of offsets and then digitizing them is way more work. A problem with scanners, is that the definition is pretty good for scanning an actual hull, but with a model, the errors may be too large.
| some small CNC enterprises have unoccupied laser scanners for small parts (customers compel them to have one for quality control), may be they can scan your model by the pound...? |
| thank you |
| thank you |
| scanner | peter radclyffe | General Computing | 17 | 07-25-2011 12:27 PM |
| one blade scanned on A4 size scanner | Çemberci | Open Discussion: All Things Boats & Boating | 7 | 05-31-2007 07:02 AM |
| Borg Warner Velvet Drive Model 72c Current Model | DAVID HOSEGOOD | Diesel Engines | 1 | 12-27-2006 12:30 AM |
| 3D model help | paul j | Software | 2 | 07-10-2006 03:31 PM |
| Scanner used to match gelcoat color | jbrown15 | Materials | 0 | 04-13-2004 11:10 AM |
