Go Back   Boat Design Forums > Design > Software > General Computing
Old 02-06-2012, 10:05 AM
LP's Avatar
LP LP is offline
Rep: 385 Posts: 671
Loss of mouse function.
I've recently purchased a couple of new laptops. An HP with an AMD Quad-Core and a Samsung with an i7 processor. Neither has interacted with the dual mouse button command that activates Rotation mode in Freeship's 3D window, either from the touch pad or the the mouse. I have a mouse with a scroll "button" that will activate the rotate command, but often times it is not convenient to use a mouse.
Has anybody else experienced this and is there a solution?
I've recently installed new CADware that utilizes the same dual mouse button push for rotation and it also is not responding. I have not found anything under mouse properties that might be an influence. My older HP functioned properly. From what I can tell, the computer is sensing both pushes, but the software is not registering the input.
Are the new processors so fast that a dual press of the mouse buttons is not sensed?
LP
God bless the open minded people of the world. LP
Old 02-06-2012, 10:27 AM
lewisboats's Avatar
Obsessed Member
Rep: 1263 Posts: 1,841
Probably not an issue...the computer is usually waiting for you 90% of the time anyways...even between double clicks. Remember...it "thinks" billions of times per second so it can take a nap between double clicks of a mouse. I'll have to download Freeship on my HP laptop and see if it likes it or not. It is probably an issue with the mouse drivers and what they are sending to Freeship. I know that years ago I had a problem with the mouse and FS and I believe I fixed it by updating my MS mouse drivers.
Steve Lewis
Lewisboatworks
http://angelfire.com/ego/lewisboatworks
Old 02-06-2012, 10:47 AM
DCockey DCockey is offline
Engineer
Rep: 1162 Posts: 1,656
What mouse are you using, a built in touch pad or an external one? Same or different than what you used before?
Operating system on new machine - Windows 7? Operating system on old machine?
Processor speed has absolutely nothing to do with how quickly you have to double click.
David Cockey
Old 02-06-2012, 11:26 AM
Rep: 3125 Posts: 9,399
Check the double click speed (and other settings) on the input device. I can't believe folks still use mice . . .
PAR Plans
PARBlog
Old 02-06-2012, 11:36 AM
lewisboats's Avatar
Obsessed Member
I'm a rodent a year man myself...wear em out I do.
Steve Lewis
Lewisboatworks
Old 02-06-2012, 12:11 PM
Engineer
Alternative - brain waves?
David Cockey
Old 02-06-2012, 01:28 PM
SheetWise's Avatar
SheetWise SheetWise is offline
All Beach -- No Water.
Rep: 574 Posts: 274
Control Panel > Mouse > Settings, speed, wheel function.
Hardware > Properties > Driver ... check for updates.
Time is Gods way to keep everything from happening at once.
Old 02-06-2012, 02:30 PM
A trackball will save your wrist a lot of discomfort.
PAR Plans
PARBlog
Old 02-06-2012, 02:31 PM
LP's Avatar
LP LP is offline
Rep: 385 Posts: 671
Sorry, Guys. I should have got baaack on here soooner. Blast that double-clickckckck.
Seriously though, I was refering to a dual button press (simultaneous depression of both the left and right mouse/touch-pad buttons). I will look into updated drivers, though.
Paul, what's your weapon of destruction?
Paul, your the fastest gun I know. You responded before I could finish typing my question. I've used trackballs in the past. They have their advantages. Mostly, I use the touchpad on my laptop. My old laptop's touchpad is well worn.
LP
Old 02-06-2012, 02:41 PM
LP's Avatar
LP LP is offline
Rep: 385 Posts: 671
DC
Old machine was Windows XP
New machines are Windows 7.
Using built in touch pads and USB mouse(old).
LP
Old 02-07-2012, 07:52 AM
LP's Avatar
LP LP is offline
Rep: 385 Posts: 671
I am finding that this may be a problem relating to Freeship. Anybody else seeing this with Windows 7? I did try a Windows XP emulation with Freeship, buit still no joy.
LP
Old 02-07-2012, 09:05 AM
Use a registry cleaning package and get ride of the paths, to the old drivers and avenues to FreeShip. It could be as simple as a path conflict and the machine defaulting to the previously known good path (Windows 7). Touch pad pointing devices aren't especially precise and painful if used much. I recently had to toss my MicroSoft trackball (the finest ever made) because in spite of my installing new micro switches, it had finally died. I'm using the Logitech wireless now, which isn't quite as comfortable as the MicroSoft, but it's close. I also use a digitizer pen and pad occasionally.
PAR Plans
PARBlog
Old 02-07-2012, 09:36 AM
Engineer
Before messing with the registry, look to see if one of the screens in mouse properties has a "software feature dependent" or similar box and check it.
I don't think clicking both right and left button simultaneously is a standard Windows feature.
David Cockey
Old 02-07-2012, 06:31 PM
It isn't David, but some software packages do permit it. Software button allocation can be a tricky business and often lads to conflicts if you're multitasking between programs with different features. This is the point of the registry cleaner, which will eliminate invalid pathways. I agree you shouldn't screw with the registry if you're unfamiliar with it.
PAR Plans
PARBlog
Form vs Function Willallison Boat Design 45 11-10-2010 04:16 AM
MultiSurf 7.0 and 3D Mouse NorthernStar Software 6 01-25-2010 11:01 AM
What's the function of pumps? MONJI Propulsion 16 09-14-2006 10:05 PM
What's the function of Drivelines? MONJI Propulsion 5 05-14-2006 07:15 AM
Mouse Gnu Cfd poul Software 0 08-27-2003 07:35 PM
