Go Back   Boat Design Forums > Design > Software > General Computing
Old 11-16-2007, 03:19 PM
fredrosse fredrosse is offline
USACE Steam
Rep: 25 Posts: 46
FreeShip Grid
The FreeShip version I have gives twenty frames, and a grid with a spacing that is not too usable, (such as 1ft - 1.6 in, 2 ft 3.2 in, etc.) on the bodyplan view. Is there a way to change the number of frames, and to change the grid, for example, to 1ft - 0 in spacing?
Thanks in advance for any help.
Fred Rosse
Old 11-16-2007, 11:26 PM
Previous Member
Rep: 0 Posts: 0
Fred
Go to menu <Calculations> <Intersections...> and choose Stations. Bin all the existing Stations and then select +N. Just set the spacing you would like for the stations.
You can do the same thing for waterlines, buttock lines and diagonals.
These settings go all the way through to give you the required grid in any orthoginal views.
Rick W.
Using FreeShip pairomedicsfish Software 12 10-05-2011 02:25 PM
FreeShip lewisboats Software 6 08-03-2009 12:52 PM
freeship files Gilbert Software 3 10-03-2006 10:39 AM
FreeSHIP 2.1 lewisboats Software 5 11-06-2005 06:35 AM
Load Grid in Hull Bottom Gone Ballistic Fiberglass and Composite Boat Building 0 08-18-2005 09:16 AM
