Go Back   Boat Design Forums > Design > Software > General Computing
Old 06-20-2010, 08:01 PM
BTG YACHT DSGN's Avatar
BTG YACHT DSGN BTG YACHT DSGN is offline
-sailing is believing-
Rep: 33 Posts: 100
.fbm to .IGES convertion (DelftShip to Rhino 3D)
I would be very grateful if somebody would be so kind and convert (export) my .fbm file so that I can open it as a precise 3D surface in Rhino (seems to call for an IGES file format).
I'm goin mad with tracing the hull lines and every time I loft the profiles the hull has some unwanted imperfections (wrinkles...).
Please do help me. It's a matter not only of the project, but also of my personal health
Kind regards,
Jakub
Old 06-20-2010, 08:21 PM
Previous Member
Rep: 0 Posts: 0
Attached.
Old 06-21-2010, 12:13 AM
Rep: 33 Posts: 100
Rick, thank you very very much That's exactly what I was expecting to have.
Regards,
Kuba
Old 06-07-2011, 06:21 AM
Rep: 33 Posts: 100
Hi ,
New project, but still old issue.... I would be very grateful if you could once again help me and convert this .fbm to .iges so that rhino has accurate model.
I'm sick of fairing curves and rebuilding and I can't make it...
Regards,
Kuba
Old 06-08-2011, 12:03 AM
micspoko micspoko is offline
Rep: 86 Posts: 194
this is file in rhino
www.pppnavaldesign.com.pl
Old 06-08-2011, 02:52 AM
Rep: 33 Posts: 100
Thank you micspoko for your help. I do appreciate your feedback However I reckon that you exported some mesh file out of DELFTship ( either .obj or .stl, rather .stl because of triangulation ). That's not quite what I was expecting for.
I tried this method some time ago, but it hardly satisfy me. IGES file is a NURBS surface perfectly working in Rhino. I can make exact deck edges (sheerline connection in particular) and I am not restricted in rendering mesh resolution.
What is more working on IGES surface allows me to transform it with multiple tools (trims, offsets ( solid shell ) etc. ).
If someone has pro version of DELFTship, then one can convert easily my file to IGES ( for a beer for him )
Old 06-08-2011, 03:40 AM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
Why don't you try to use Freeship? I routinely export IGES from Freeship to Rhino with no problems encountered so far.
You can find it here: http://www.hydronship.net/index.php?lang=en
Cheers
Old 06-25-2011, 04:51 AM
Rep: 33 Posts: 100
Indeed, exporting IGES file from FREEship is working well, however I have to remember to model the surface in the FREEship, not in DELFTship.
The reason for that is FREEship does not recognise the .part files of DELFTship. By now I'm reconstructing the whole model point by point (control point) from DELFT to FREE. Then the export is not a problem at all
Thank you, daiquiri for reminding me of possibility to export IGES files using FREEship instead of DELFTship, where this feature is unavailable in statndard version
Regards,
Kuba
Old 06-25-2011, 04:06 PM
Adler's Avatar
Adler Adler is offline
Rep: 110 Posts: 98
what you need....
Is attached.
Old 01-21-2012, 05:04 AM
johnswe johnswe is offline
Delft->Rhino
Could someone please help me with the same problem? I would be very thankful.
Best regards
John Swe
Old 04-28-2012, 04:14 PM
Adler's Avatar
Rep: 110 Posts: 98
Your file is converted.
Delftship - Rhino Mudz Software 9 12-02-2011 09:14 AM
iges from Rhino to maxsurf workshop lazeyjack Software 3 02-28-2008 05:45 PM
Importing IGES to Rhino & Rendering Mat-C Software 4 09-07-2007 12:48 PM
DELFTship 3.1 IGES Import sorbit Software 2 03-27-2007 03:20 AM
Importing Maxsurf IGES to Rhino as a workable surface SOYUTA Software 14 02-05-2007 02:03 PM
