Go Back   Boat Design Forums > Design > Software > General Computing
Old 02-13-2009, 03:47 PM
apex1
Excel quit the scene, need Help !
Hello dear fellow members,
after installing a Microcrap hotfix my Excel disappeared. All the other office 2000 applications work properly, but when I try to open a Excel file IŽll get asked to insert the office installation cd. I am still in Turkey and will stay here for several more weeks (or even some month), so I doŽnt have my software installation CdŽs here.
I can go through "start" "new office document" "excel sheet" and create a new sheet, then open the existing one, but when I try to save it, iŽll be asked again to insert my cd.
Any idea what went wrong? Maybe i have to fix the file allocation?
A system restore did not help.
Would like to work again,please help.
Regards
Richard
Old 02-13-2009, 06:46 PM
daiquiri's Avatar
Engineering and Design
Rep: 2340 Posts: 2,472
Have you tried to check the "General" tab in Tools-->Options menu command?
Somewhere in that tab you'll see a line which reads something like "Default file folder" (I have the italian version, so don't know if that is the correct english translation). That's where Excel will save your work, so check out if the save path is correct. If it reads "E:\" or whatever your CD drive's name is, that could be the reason.
Old 02-13-2009, 07:06 PM
apex1
You mean "in the opened Excel sheet"? Have checked that, setting is correct!
Prob is Excel does´nt open without a trick. Windows installer appears and asks for cd. see above
Old 02-15-2009, 09:48 AM
apex1
May I push the topic up a bit?
Old 02-15-2009, 11:18 AM
Wynand N's Avatar
Wynand N Wynand N is offline
Retired Steelboatbuilder
Rep: 1544 Posts: 1,138
do what I did - dump Microsoft.
Download OpenOffice bundle software for free and you have a more stable platform that is in my view better than MS.
Even saves files in a PDF at the touch of a button and the new version on its way can even open PDF files to edit...
Wynand
A scatterling of Africa
Old 02-15-2009, 12:32 PM
apex1
Thank you Wynand. I have Star Office (now open office) in use since 1994, and agree with your statement.
Unfortunately I need Excel daily to be compatible with my architects and constructors.
I must solve this problem, if I like it or not.
Regards
Richard
Old 02-18-2009, 09:41 PM
apex1
No help in sight.........................
Microbrain would assist, but charge me 72€ just for one e-mail enquiry! Hefty rates, no wonder there are copies all around. I could buy the actual version here for some 40 lira (30$), but really do´nt like that way.
Any better idea?
Old 02-19-2009, 05:57 AM
daiquiri's Avatar
Apex, are you sure Open Office's Calc spreadsheet is not compatible with Excel? I think it is, both in read and in write (save as ".xls" option) and is worth trying, imho.
Old 02-19-2009, 09:09 AM
apex1
Thank you, yes since ages Star office / Open office is able to handle xls files. Unfortunately it doesŽnt keep the styles / formatting properly. Means, if I receive a file from my architect in Vietnam, do my changes and send it back, he has a document thats different from his original. And thats daily part of my business.
Regards
Richard
Old 03-15-2009, 05:39 PM
Jack Daniels Eq's Avatar
Jack Daniels Eq Jack Daniels Eq is offline
Shockwave
Rep: 11 Posts: 50
Try click on the executable for excel, also try to reinstall it - its somewhere in the main Office hierarchy, or try the repair menu, also in Office main menu
Sorry - havent used MS anything in 5 years - a little rusty
BR>Jack
Old 03-15-2009, 07:48 PM
apex1
Solved the prob, bought a new!
Thanks Wynand and daiquiri !!!
Old 03-15-2009, 10:02 PM
Rep: 472 Posts: 1,391
Apex do what I did introduced everyone I work with to openoffice... They all switch because it give less trouble and pdf thing. Now they all work together Macs, Pc, and Linux...
Old 03-15-2009, 10:23 PM
apex1
As mentioned above, that is no solution! And I work with Star Office since ages (1993).
Regards
Richard
Rig design, will you check my Excel file? Gades Boat Design 9 11-10-2010 04:12 PM
Excel Spreadsheet Ekaiztea General Computing 11 08-08-2010 06:30 AM
excel to DXF format conversion mcollins07 Software 4 12-04-2008 06:15 PM
control panel for lights and 12v plug in quit working jd87 Electrical Systems 0 08-04-2008 01:58 PM
Wellcraft Excel 21SL? Alexx Powerboats 1 11-01-2004 03:02 PM
