Go Back   Boat Design Forums > Design > Software > General Computing
Old 02-04-2009, 09:18 AM
apex1
Compression, downsizing of pictures, need help!
Hello to all,
I am annoyed by a real silly little problem everytime I want to upload a picture.
How can I downsize a picture I have taken with my digital camera, in the most efficient way (without loosing too much of the impression it reflects).
In terms of editing pictures I´m a total layman! I use "the Gimp" to edit and "Irfan View" to sight. And I do´nt want to install another program.
I am not at home or in my office, I am in Turkey at present. Although the internet connection here is at a reasonable standard, uploading files takes ages (20 minutes for 300 kb), at least with my provider.
I tried to solve the prob. by: first downsizing to a usable size, say 15%, then reducing the resolution to 60 dpi, then on top reduced the colours to 256. The result is a size within 60 to 200 kb, but the pictures look poor.
Any cheap trick?
Thank you in advance!
Regards
Richard
Old 02-04-2009, 02:06 PM
apex1
To give a better description of the result I would like to achieve:
if you look at my Gallery, especially this picture:
http://www.boatdesign.net/gallery/sh...1/ppuser/11121
more than 300kb but poor quality. Now look at that:
http://www.boatdesign.net/gallery/sh...4/ppuser/11121
55kb but bright and clear!
I unfortunately cannot find out, who did compress (manipulate) it.
Every assistance greatly appreciated.
Regards
Richard
Old 02-04-2009, 02:14 PM
daiquiri's Avatar
Engineering and Design
Rep: 2340 Posts: 2,473
The first image was saved to jpg format with almost no compression. I've opened it with PaintShop and saved it again with 10% compression factor and it is 80 kb now, nearly same visual quality.
What photo software do you use?
Old 02-04-2009, 02:18 PM
apex1
Thank you very much, the software is mentioned above! I´ll look if I have some feature!
edit: No, at least I could´nt find it
Regards
Richard
Old 02-04-2009, 03:35 PM
Guest62110524 Guest62110524 is offline
Previous Member
Rep: 0 Posts: 0
there is a much easier solution picasa 3 free from google allows you to instantly easily crop a pic, save sent to microsoft image or otherAlso hit print screen and with picasa open , what is on screen comes up in picasa, crop it and there you have a file to send use do what you will with)
Old 02-04-2009, 03:38 PM
Previous Member
Rep: 0 Posts: 0
like so, abt 100 times faster than paint
Old 02-04-2009, 03:52 PM
apex1
Thanks Stu, will google that! Problem is, I have just my notebook here and that is packed with Data and program till upper edge lower lip. Just 254 mb left!!!
No way to install another program, and have already two external hd in use! shi....t
Thanks for assistance.
Regards
Richard
Old 02-04-2009, 05:21 PM
robherc robherc is offline
Designer/Hobbyist
Rep: 102 Posts: 433
You can try saving it to .PNG format, that usually shrinks things up a good bit for me, and most current browsers will read it as well as a .jpg :-) (I'm not completely sure if that format's allowed in here though...will have to check on that)
Old 02-04-2009, 05:33 PM
daiquiri's Avatar
GIMP is a great photo editing software and, incredibly, all for free.
You will find all the instructions here:
http://docs.gimp.org/en/
Read the chapter 6.
Old 02-04-2009, 05:56 PM
apex1
Read the chapter 6.
Thank you very much! ALL
Regards
Richard
Old 02-04-2009, 06:07 PM
Previous Member
Rep: 0 Posts: 0
I find PowerPoint to be an easy to use means of compressing photos. It is already on most computers. It has a good jpg converter although you cannot alter its compression ratio.
The attached images compare straight from the camera versus same image just inserted in PowerPoint and SavaAs jpg. The ratio in file sizes is about 12 : 1.
If you have a series of photos you can insert them all into PowerPoint and when you SavaAs they will be placed in a folder, each as a jpg image.
PowerPoint is a reasonable tool for quick sketching and image manipulation. It is worthwhile spending a little time to play with these functions if you have not done it already.
Rick W
Compression, downsizing of pictures, need help!-compressed.jpg  Compression, downsizing of pictures, need help!-dscf1297.jpg
Old 02-04-2009, 06:10 PM
Previous Member
Rep: 0 Posts: 0
Actually if you have a Mac it is a single mouse click to get any part of the screen.
Rick W
Old 02-04-2009, 06:28 PM
Previous Member
Rep: 0 Posts: 0
Rick W
mouse click, Rats I do not have a mac
Old 02-04-2009, 06:32 PM
apex1
Rick W
Impressive, Thanks! Yes naturally I have powerpoint on my laptop. IŽll try!
Thanks to daiquiri, I found out now that the "Quality" switch in Gimp is related to compression ratio (or say, I believe it is) and that solves the problem for now! Will make immediately a upload to my Gallery (Red boat, not built at my yards).
Again thanks to ALL of you nice guys !
It is really not a big problem to be a disabled *****, as long as you know whom to ask!
Regards
Richard
Old 02-05-2009, 02:14 AM
Designer/Hobbyist
Rep: 102 Posts: 433
You're EXACTLY right...it was called "Quality" in iPhotoPlus4 (my personal fav. image manip. software of about 12 years ago...rofl.
Mast Compression Loads yades Sailboats 26 08-09-2009 05:49 AM
What is the importance of a compression sleeve on spreader bolts? bntii Boat Design 6 08-19-2008 01:39 AM
Compression test mercruiser 350 magnum rossmon1 Sterndrives 2 06-26-2006 01:23 AM
?? about compression pipe in a mast!!! MarioCoccon Sailboats 3 04-26-2006 08:42 AM
Halyard Locks reduce mast compression? luistem Boat Design 9 01-27-2005 10:37 PM
